Hello dear developers,
I’m having a hard time showing a custom-built data set in the information panel of ParaView. This custom dataset is a child of vtkPolyData in the form of:
class MODULE_EXPORT meshDataSet : public vtkPolyData
public:
static meshDataSet *New();
vtkTypeMacro(meshDataSet, vtkPolyData);
void PrintSelf(ostream& os, vtkIndent indent) override;
* Datasets are composite objects and need to check each part for MTime
* THIS METHOD IS THREAD SAFE
vtkMTimeType GetMTime() override;
* Return the type of data object.
int GetDataObjectType() override { return MESH_DATA_SET; }
protected:
// Constructor with default bounds (0,1, 0,1, 0,1).
meshDataSet();
~meshDataSet() override;
private:
meshDataSet(const meshDataSet&) = delete;
void operator=(const meshDataSet&) = delete;
This almost works. I had to modify Common/Core/vtkType.h to include my new data type:
Link: https://gitlab.kitware.com/vtk/vtk/blob/master/Common/Core/vtkType.h
#define VTK_PISTON_DATA_OBJECT 34
#define VTK_PATH 35
#define VTK_UNSTRUCTURED_GRID_BASE 36
#define VTK_PARTITIONED_DATA_SET 37
#define VTK_PARTITIONED_DATA_SET_COLLECTION 38
#define MESH_DATA_SET 39
(I feel like another approach would be better here since more datatypes will be added in the future.)
Now, I created another class called “MeshReader”, a source proxy, which does nothing except initializing an object through a single output port in the ParaView pipeline:
int MeshReader::RequestData(
vtkInformation* vtkNotUsed(request),
vtkInformationVector** vtkNotUsed(inputVector),
vtkInformationVector* outputVector)
vtkInformation* outInfo0 = outputVector->GetInformationObject(0);
meshDataSet *output = meshDataSet::SafeDownCast(
outInfo0->Get(vtkDataObject::DATA_OBJECT()));
int MeshReader::FillOutputPortInformation(
int vtkNotUsed(port), vtkInformation* info)
info->Set(vtkDataObject::DATA_TYPE_NAME(), "meshDataSet");
return 1;
Then, I added a new vtkDataObjectType:
Link: https://gitlab.kitware.com/vtk/vtk/blob/master/Common/DataModel/vtkDataObjectTypes.cxx
else if(strcmp(type, "vtkMolecule") == 0)
return vtkMolecule::New();
else if(strcmp(type, "vtkArrayData") == 0)
return vtkArrayData::New();
else if(strcmp(type, "vtkPath") == 0)
return vtkPath::New();
else if(strcmp(type, "vtkPartitionedDataSet") == 0)
return vtkPartitionedDataSet::New();
else if(strcmp(type, "vtkPartitionedDataSetCollection") == 0)
return vtkPartitionedDataSetCollection::New();
else if (strcmp(type, "meshDataSet") == 0)**
vtkStringArray* meshDataSetInfo = vtkStringArray::New();
meshDataSetInfo->SetName("meshDataSet");
meshDataSetInfo->InsertNextValue("meshDataSet");
vtkPolyData* meshDataSet = vtkPolyData::New();
meshDataSet->GetFieldData()->AddArray(meshDataSetInfo);
return meshDataSet;
Here, I used a StringArray to differentiate it from a usual vtkPolyData because I can’t link my meshDataSet.cxx class with vtkDataObjectTypes.cxx in CMake.
To be able to show “meshDataSet” in the information panel, I added my own detector:
int dataType = this->DataSetType;
if (this->CompositeDataSetType >= 0)
dataType = this->CompositeDataSetType;
// Custom types
if (this->FieldDataInformation->GetNumberOfArrays() > 0)
if (this->FieldDataInformation->GetArrayInformation("meshDataSet"))
return "Mesh Dataset";
switch (dataType)
case VTK_POLY_DATA:
return "Polygonal Mesh";
This code is able to show me “Mesh Dataset” in the Information Panel when I instantiate my “MeshReader”, but as soon as I press “Apply” in the properties panel, the data type switches to “Polygonal Mesh”. What could be wrong about this approach? Am I forced to link vtkDataObjectTypes.cxx with meshDataSet.cxx?
Thank you,
Patrick
