msw
May 4, 2021, 1:28am
1
Hello Everyone
Great to meet you.
I just started with Paraview.
I have to render the mass data to volume. I have a .csv file of the mass data. How to do that?
I understand my question can be vague as I said I am starting I don’t know how to ask good questions.
I would appreciate your response.
mwestphal
(Mathieu Westphal (Kitware))
May 4, 2021, 7:29am
2
please share the csv file as well as the volume file.
msw
May 6, 2021, 2:05am
3
I am sharing the CSV headers
Point ID | D | M | Points | Points_Magnitude
0 |6.46e-10| 6.46e-10 | -1.5 , -1.5, -1.5 (x,y,z). | 2.598080
I need to render Mass as a volume (and I don’t have any volume csv I believe)
I would appreciate your help
msw
May 6, 2021, 9:02am
5
Thanks !! I really appreciate it.
I will do that.
Does after resampling to image do I need to use Filter Table to Structure and then render it as a volume to get my answer?
mwestphal
May 6, 2021, 9:06am
6
no, just render as a volume.
TableTOStructuredGrid could also work, hard to say without your data.
mwestphal
May 6, 2021, 9:09am
8
Select volume instead of outline or surface.
msw
May 6, 2021, 9:11am
10
Sure thank you I have also shared the csv file.
msw
May 6, 2021, 2:12pm
11
Thank you for you kind response and help.
I also need to use thresholding on the Mass value (M) I used the Thresholding filter but I didn’t saw any change in the Visualization. I am pretty much confused → after changing to Table to Points → I used thresholding all colored in “M”. I don’t know how whether my approach is wrong or right.
Can you suggest something. I would really appreciate it.
