CSV table data to 3D
I’m new to Paraview. I have CSV data in table format. So the rows represent Y, and the columns represent X, and for each cell, the Z value is stored. Can I use Paraview to generate the 3D view?
for example, as below, ABCDEFG are columns representing X, and 12345 in the left are rows representing Y. The numbers indicate the Z value.
/t A B C D E F G
1 2 2 3 3 4 4 4
2 1 1 2 2 3 4 5
3 2 2 3 3 5 5 5
4 2 2 22 2 3 4 5
5 4 5 5 5 5 5 5
CSVReader + TableToStructuredGrid should work
Uploading: eye height high mag.csv…
Sample.csv (21.8 KB)
Hi Mat, thanks for the reply. I’ve attached a sample file. The file is not structured as XYZ columns. The columns, A, B,C,D …represent X-axis (they are in arbitrary units), and rows 1,2,…38 represent Y-axis (with arbitrary units), and each cell value represents the Z value (hight). I’m having trouble reading this with Paraview. I’d like to display 3D structure but not sure how. Thanks.
One way to achieve this is to use a Programmable Source.
  1. Source > Alphabetical > Programmable Source
  2. Fill in the Script (RequestInformation) as shown below.
from paraview import util
util.SetOutputWholeExtent(self, [0, 98, 0, 37, 0, 0])
Here, the values to be specified for SetOutputWholeExtent are obtained by counting the number of rows and columns from the csv file in advance.
  1. Enter the following in Script.
import numpy as np
path = 'data_path/Sample.csv'
a = np.loadtxt(path, delimiter=',', encoding='utf-8_sig').flatten()
output.SetDimensions(99, 38, 1)
output.SetOrigin(0.0, 0.0, 0.0)
output.SetSpacing(1, 1, 1)
output.PointData.append(a, 'height')
Here, path is the absolute path to the location of Sample.csv. And set the number of rows and columns in the csv file in output.SetDimensions.
  1. Specify vtkImageData as the Output Data Set Type.
  2. Apply
  3. Continue to apply Filters > Alphabetical > Warp By Scalar, as shown below.
The state file for the above operations is attached.
programmable_source.pvsm (292.2 KB)
Thank you for the very detailed reply. I’ll give it a try. Much appreciated.
