custom paraview module - How to generate embedded doc
I created a new vtk module and I used the following function to append my filters.xmls
set(classes
  testClass
set(xml_files
  Resources/test_filters.xml)
vtk_module_add_module(ParaView::TestModule
  CLASSES ${classes})
paraview_add_server_manager_xmls(
    XMLS  ${xml_files})
The filters appear in ParaView but how do I generate the “embedded documentation”
A plugins generate the doc using the {project}_doc & {project}_qch projects
This can be done with:
paraview_client_documentation(
  TARGET mymodule_doc
  XMLS ${xml_files})
I suppose this actually makes more sense to be part of ParaViewServerManager.cmake, but it lives in the client CMake API for now. That call ends up making a bunch of .html files you can bundle up however you want. The paraview_client_generate_help function is provided for clients to make Qt help resources.
thank you !
