I refer to the Examples/Plugins/PropertyWidgets example, I customized a plugin, I found that the property panel can be customized, but after the Apply button is triggered, the other public parts of the property panel are displayed.
Question: Can the plugin’s properties panel be fully customizable? (if the public part is not displayed)
According to your method, the public properties of the property panel can be hidden; but after this setting, the public properties of all objects are hidden. If only for a certain type of object, you need to hide its public properties; other types of objects , need to display public properties, is there a way to do it?
What do you mean? I did not understand? For example, if you have a type of object, you don’t need to display “color” and “Opacity”. What should you do?
If you want to hide specific properties, like in your case, the edit color or the opacity property, you need to create a XML plugin that will override the visibilities of the properties.
This is doable but not easy if you never heard of XML only plugins.
