display certain elements above a threshold in a color
Dear all,
I compare different data sets whose data range differs, for instance Data1 values are in the intervall [0;15] and Data2 values in the intervall [0;25].
First, I would like to have both legends on the same intervall, for instance [0;15]. I rescaled the legend such that both views have the same legend range which also worked.
However, the values from Data2 in the intervall [15;25] are depicted in the color associated with the value 15.
What I would like to achieve is that the values above 15 are depicted in, for instance, grey, in order to indicate that these values are indeed above 15 and not equal to 15.
What is the way to do this in paraview?
Any input is appreciated!
Best
To set up out-of-range coloring, enable the advanced properties (gear icon) in the Color Map Editor, then turn on Use Below Range Color and Use Above Range Color in the Color Mapping Parameters, and change the respective colors in Below Range Color and Above Range Color.
Thank you, that is exactly what I was looking for!
