Hello everyone,
I am using paraview for the first time.
I have results from a numerical modelling in which I applied pressures to a portion of the model. The model represents a natural slope. Part of the right-hand free surface of the model is subjected to an external action that exerts pressures on it. These pressures are very low (max. 40kPa) compared to those already present within the model, but nevertheless important for the study I am conducting. For this reason, through the interface of the software with which I have conducted the modelling, I am unable to display any pressure difference between the surface on which I have applied these pressures and the rest of the domain due to a scaling effect.
In Paraview, I would like to be able to enhance the aforementioned pressures so that I can display them correctly. Can anyone suggest a strategy for doing this?
This is an example of what I mean:
You see that in this case (in which the applied pressures are much larger than those I mention above, i.e. in the order of 20MPa) I can visualise the applied pressures well because they are much larger than those already in the model.
Thanks a lot for your support,
FF
