I have a set of VTK files which is a 3D cube. I have attached the link to it below. I have loaded into the paraview and have created an animation view of it.
Now I want to display a variable “i” in the render view itself, as the animation progress. ( The variable ‘i’ has int value)
Example:
I have kept the animation frame number to 600. The start time is 0 and the end time is 6.
So as the animation progresses from 0 to 6, I want to print the variable ‘i’ in the render view
VTK file: https://drive.google.com/open?id=1eN79xMyed0Uj9Uyugv5YSskwtzXsquTn
Thanks for your response.
That helped me a bit, but it would print the current time, which is not the required result.
Say for example:
for i in range (1,5)
print(i)
This would print 1 to 4, which is what I want to print.
Is it possible?
@cory.quammen
I want the variable to be dynamic. Your expression gives me a static variable where the all the values are printed in the beginning itself.
is it possible to change it as the animation progress?
I’m doing the best I can with the description you have provided up to this point. How do you plan to set the variable “i”? Is it a function of time? Do you want to set it in the GUI. Please be as specific as possible.
I have 7 VTK files ( have provided the link before), whose animation has to be created. During the animation, I want to display a variable " i " to be displayed in the GUI ( side by the 3D cube). The value of “i” varies from ( 16.095 to 7.221, decreasing order) i.e as the animation progress with the time, the value starting from 16.095 up to 7.221 has to printed.
