I know how to calculate distance between points (the Sources/ Ruler). Is there a way to calculate the distance between two points for many timesteps? Thanks!
@cory.quammen @utkarsh.ayachit Ping. This is for a customer.
One option is to the select and extract the “two points” ever which way you like ant then use Bounding Ruler.
We shuold really make the filter output the distance as a cell-data variable too (currently, it only shows it on screen). That way one could use Plot Over Time for example to see how the distance changes over time.
