Docker images
I am looking at docker images for ParaviewWeb. The documention refers to this dockerhub repository but it looks outdated (latest version is 5.8): Docker Hub
Is there another repository or should we build the docker ourself?
Thanks for the help
That is the correct spot. We are just manually building those images and we did not push a new one for 5.9. On the other hand, 5.9 had an issue with the Web due to some issue when handling so python dependency/dependency.
You should be able to build your own image using master (the 5.9 issue has been solved) using those image definitions here (PV) and here (Web)
dev image fails to build for the following parameters:
BASE_IMAGE=ubuntu:18.04
PARAVIEW_TAG=v5.9.0
SUPERBUILD_TAG=v5.9.0
RENDERING=osmesa
PYTHON_VERSION=3
During image creation python3.6 installed, however some of the dependencies needs python >=3.7.
For osmesa, it might be simpler to just used the linux osmesa binaries and untarring them within your docker.
