I’ve been trying to analyze results in Paraview from a simulation of what I did in Elmer of a 3D reactor. My ultimate goal is to compare the results between this 3D reactor simulated in Elmer and a 2D reactor simulated using FEMM.
On the Elmer, I applied a current of 30,000A to the coil and checked through ElmerVTK that this current seemed ok. However, on Paraview the result was different. In Paraview, I used Slice to then integrate the coil surface through the Integrate Variables filter. Note that the coilcurrent values in the X Y Z axes obtained with this filter are different from those observed in the other column and are also not in accordance with the expected results.
I am sending the pictures , .vtu and .fem files below.
Reactor.zip (1.4 MB)
Could you help me understand where I might be going wrong?
I’m new to these simulations and I’m still learning. Thank you for the help!
