Drag and drop in custom application does not work
I built ParaView from the master branch, then used this ParaView to build the SimpleParaView example application. Drag & drop a file to the render window works in ParaView that I built, but not in the custom application. Was drag & drop deactivated on purpose in the SimpleParaViewI?
In ParaView/ParaViewMainWindow.cxx there is this code:
void ParaViewMainWindow::dragEnterEvent(QDragEnterEvent* evt)
  pqApplicationCore::instance()->getMainWindowEventManager()->dragEnterEvent(evt);
void ParaViewMainWindow::dropEvent(QDropEvent* evt)
  pqApplicationCore::instance()->getMainWindowEventManager()->dropEvent(evt);
And also the following in ParaView/ParaViewMainWindow.ui
  <property name="acceptDrops">
   <bool>true</bool>
  </property>
Which is not present in SimpleParaView
Thank you. Does it need modification in the build system? Adding these (along with the declarations in the header file) was not enough:
/home/zc/paraview/Examples/CustomApplications/SimpleParaView/client/myMainWindow.cxx: In member function ‘virtual void myMainWindow::dragEnterEvent(QDragEnterEvent*)’:
/home/zc/paraview/Examples/CustomApplications/SimpleParaView/client/myMainWindow.cxx:88:61: error: invalid use of incomplete type ‘class pqMainWindowEventManager’
   88 |   pqApplicationCore::instance()->getMainWindowEventManager()->dragEnterEvent(evt);
In file included from /home/zc/paraview/Examples/CustomApplications/SimpleParaView/client/myMainWindow.cxx:7:
/home/zc/paraview_install/include/paraview-6.0/pqApplicationCore.h:17:7: note: forward declaration of ‘class pqMainWindowEventManager’
   17 | class pqMainWindowEventManager;
/home/zc/paraview/Examples/CustomApplications/SimpleParaView/client/myMainWindow.cxx: In member function ‘virtual void myMainWindow::dropEvent(QDropEvent*)’:
/home/zc/paraview/Examples/CustomApplications/SimpleParaView/client/myMainWindow.cxx:94:61: error: invalid use of incomplete type ‘class pqMainWindowEventManager’
   94 |   pqApplicationCore::instance()->getMainWindowEventManager()->dropEvent(evt);
Probably an include ?
I included
#include <QDragEnterEvent>
#include <QDropEvent>
so it shouldn’t be the problem. By the way, Clients/ParaView/ParaViewMainWindow.cxx only includes QDragEnterEvent, so QDropEvent must be included implicitly.
#include "pqMainWindowEventManager.h"
Sorry, my bad. It works now.
