Hello @jfausty ,
Thank you for your detailed response. I use deal.ii and generate *pvtu/*vtu files from that. I don’t think I can shift to an structured grid as in some time steps I will have huge distortions. Below is the initial grid:
The final grid looks like this:
Is there no way of applying contour filters on the *pvtu file? I use large number of processes and view these files using paraview from a remote cluster. Merging them into a single file makes it too cumbersome to work with.
Also, I tired using merge blocks filter as mentioned here, but the filter is unavailable.
Do you have any other suggestions on this?
Thanks again,
Raghunandan.
