I’ve been trying to use a python script to render about ~1000 Line() objects. This is a simple task to perform, but it takes a long time. As a very bare bones example, if you process the following in the python shell:
test = [None]*1000
for i in xrange(len(test)):
…test[i] = Line()
it takes roughly 10 seconds (on my laptop anyway) for the objects to show up in the pipeline browser. It then takes about 3 times as long to render all the line objects. I’m looking for a way to speed this process up through parallelization, as this seems like an embarrassingly parallel routine.
I have tried running a script using pvbatch that was called by mpiexec.hydra -np 8. I didn’t really see nor expect a speed increase however, because my code uses standard python for-loops to create and render the source objects (lines). I considered playing around with the python joblib package to see if that sped things up, but for now joblib is not working in my pvbatch environment (at work I don’t have the privileges to fix this). Would this be a reasonable route to pursue to improve performance?
Finally, to articulate an actual question: is there a fast method, or efficient coding practices I can use to quickly instantiate and render > ~ 1000 simple source objects (e.g. lines, cones, boxes) in python? Any guidance would be greatly appreciated.
The data set I’m working with is a large ascii format collection of start points and endpoints for disconnected line segments (I could convert to .csv), so my first thought was to create a python script with a loop that would draw a line segment for each pair of points. This became too slow once I included too many line segments.
I’m not sure how to render hundreds of lines with a single source object–the poly line isn’t quite what I need since the segments are disconnected. I might try playing around with the .csv reader because I’ve used that before to visualize very large (~1M points) data sets fairly quickly.
This is going to work. It also leads to the solution to my more general question in the OP. One followup question:
Right now I’m generating the point and cell data using the legacy vtk file format. Is there a wiki or document describing a better way that I should be doing this within paraview? Unfortunately I don’t have experience with xml (maybe this is a good time to learn).
