Ellipse
Hi!
Is it possible to visualize an ellipse on Paraview? Is it possible to create a vtk file to input this type of geometry? How?
Thanks,
Marina
Menu Sources/Alphabetical/Ellipse create a polygonal mesh (vtkPolyData) representing an ellipse (with the given resolution).
VTK files store meshes and not parametric objects. That said you can save your created ellipse as a mesh in a vtk file: File/SaveData.
To followup what @nicolas.vuaille said, there is an Ellipse source coming to ParaView 5.8, but it is not available in ParaView 5.7. Until 5.8 is out, you can add a Disk source, add a Feature Edges filter to it to extract the circular boundary of the disk, then finally add a Transform filter to warp the circle into an ellipse.
ahh ok! I wasn’t finding the ellipse source. So, I will wait for this.
For now, I am using the other procedure you commented on (@cory.quammen). It worked!
Thanks,
Marina
