I’ve downloaded ParaView-5.11.2-MPI-Windows-Python3.9-msvc2017-AMD64, and am trying to enable the “AutoMPI” option some of the earlier posts here had mentioned in order to run over multiple processors. I don’t find the option in this present version. Am I missing something? I’m new to ParaView, and would greatly appreciate your help with this query. Thanks!
Hi @Roger1198
AutoMPI has been deprecated and removed in ParaView 5.10 I believe.
Just run pvsevrer distributed manually instead.
.\bin\mpiexec -np 4 .\bin\pvserver
Then connect to it.
Hi, Mathieu. Thanks for the reply.
The command you’ve provided looks like something I’d have to type in an Ubuntu terminal. I’m running Win10. Is there another option for the above, or would you recommend re-installing ParaView on Ubuntu? Thanks
The command I provided should be run from a windows terminal.
then it should be:
.\mpiexec.exe -np 4 .\pvserver.exe
please type dir and share the complete result.
Okay, I seem to have got it connected. Had to specify the full path of mpiexec.exe. I can now connect to the server. The change in post-processing speed is palpable!
