We have two CMake variables, VTK_NO_PYTHON_THREADS and VTK_PYTHON_FULL_THREADSAFE. These are defaulted so that we don’t use GIL locking in ParaView builds by default. I am wondering if we should indeed enable Python thread support so that programmable filters can be written that use threading and other thread-based async features in Python.
Tomviz uses these options to force GIL locking in ParaView. A while ago I tried to set up a ParaView dashboard with these enabled, but there were some test failures I didn’t have time to solve at the time.
We should not be making too many C+±2-Python calls in tight data processing loops, so that’s not a major concern. C+±2-Python path if often only for “plumbing”, setting up the pipeline, etc.
There is a separate issue where pvpython doesn’t seem to exit gracefully. I’ll track that down in time.
I thought we turned GIL off at the PV 5.0 transition because GIL was incompatible with some high profile python libraries? If my recollection is correct and that is still the case we still don’t want it on by default.
