Error: Failed to read data. Algorithm returned failure for request: vtkinformation
Hello, I’m a very recent Paraview user and can’t seem to see what is causing the problem I face. I have multiple solution.xdmf files that I am able to load into paraview and can observe the maximum timestep of the solution. I am able to play with the data, contour it, clip it etc, but as soon as I try to view any time step that isn’t the max, the program close. If I load the file using Xdmf3 Reader It will not even output the error message, the error box will pop up then close immediately as well! If I use Xdmf Reader it will output the message below. I would like to be able to view all the time steps and make an animation, any help with why this error is happening is appreciated! I am using Paraview 5.5.2.
Thanks
ERROR: In C:\bbd\7cc78367\build\superbuild\paraview\src\VTK\IO\Xdmf2\vtkXdmfReader.cxx, line 421
vtkXdmfReader (0000021D50C19C70): Failed to read data.
ERROR: In C:\bbd\7cc78367\build\superbuild\paraview\src\VTK\Common\ExecutionModel\vtkExecutive.cxx, line 784
vtkPVCompositeDataPipeline (0000021D590356C0): Algorithm vtkFileSeriesReader(0000021D595BA2B0) returned failure for request: vtkInformation (0000021D5D247BF0)
Debug: Off
Modified Time: 291375
Reference Count: 1
Registered Events: (none)
Request: REQUEST_DATA
FORWARD_DIRECTION: 0
ALGORITHM_AFTER_FORWARD: 1
FROM_OUTPUT_PORT: 0
my best guess is a bad data file. Could you post a file that shows this behavior here?
Here is one of them.
solution.xdmf (276.5 KB)
Hi, did you solve this error in the end?
