I am a new ParaView user and I noticed that whenever I try to load up a render view with Surface LIC display, an error code is showing up in the output window.
I am unsure as of what is causing the error, as the rendering seems to load up OK and LIC plot looks as expected.
Could you please have a look at the error message attached and advice on troubleshooting? As it seems to be graphics related, it might be worth mentioning that I am using a workstation with Nvidia Quadro K 2200 chip.
Add Slice filter to exisitng source (volume mesh with calculate Velocity vector)
Change to SurfaceLIC representation
Change coloring to “U”.
As I mentioned the LIC plots show OK, although the error output message is concerning and annoyingly reproduces with every camera zomm / rotation / pan etc.
So: both applying LIC to Wavelet source with Gradient filter and resetting settings to default (I am running on Windows so I used option Edit->Reset to default settings) and applying LIC to my source worked and did not yield any errors.
Any idea what custom setting could be causing an issue in the original case?
Interesting. It’s hard to say which option may be interacting with Surface LIC negatively. Did you happen to back up your settings when choosing Edit->Reset? If so, mind sending me the backed up files? They should be under C:/Users/USERNAME/AppData/Roaming and have the extension .bak.
I would actually expect some of the options that default to on (depth peeling, FXAA) might be having an effect somehow, so it’s surprising that resetting to the default settings fixes things for you.
I am also seeing the same error whenever I use surface LIC. I am using paraview 5.4.1.
initially,
When I load my case file and click “Apply”, I see an error message
[ERROR: In C:\bbd\2d618e80\build\superbuild\paraview\src\VTK\IO\EnSight\vtkEnSightGoldBinaryReader.cxx, line 2267
vtkEnSightGoldBinaryReader (0000023852A76A20): Unknown element type "coordinates "]. In the selection dropdown list I am seeing velocity as "velocity(“partial”). But everything after this looks as expected.
Later when I load surfaceLIC, I see the message paraview error.txt (5.4 KB).
How can I fix this error?
