Whenever I apply a clip or slice to a netcdf-volume and save the state, an error message appears when opening the state:
ERROR: In C:\glr\builds\paraview\paraview-ci\build\superbuild\paraview\src\VTK\Common\ExecutionModel\vtkDemandDrivenPipeline.cxx, line 760
vtkPVDataRepresentationPipeline (0000023D15BA3CB0): Input for connection index 0 on input port index 0 for algorithm vtkImageSliceRepresentation(0000023D15DEC140) is of type vtkRectilinearGrid, but a vtkImageData is required.
Everything renders fine and as expected, so my “workaround” has always been to just ignore the error message. I was just wondering why the message appears and if there is a little trick to avoid it?
Just to be clear: no error message appears when I apply the clip or slice (nor later on). It only pops up when I open a state where a clip or slice is saved.
Thanks and cheers,
Venke
