Hi all,
I am pretty new to Paraview and pvpython. I used to use paraview client GUI to load data and generate image and animation. But I would like to learn to use pvpython instead. Firstly, I used “Trace” feature in paraview client GUI to record my action with Python script. However, when I tried to run the save script from “Trace” in pvpython, I got an error message when reading VTK files. I didn’t run into any problems when I read the data with paraview client GUI. The error message is as below. I wonder what does the error mean and how should I solve this. Any thoughts would be greatly appreciated. Thank you!
# trace generated using paraview version 5.10.1
#import paraview
#paraview.compatibility.major = 5
#paraview.compatibility.minor = 10
#### import the simple module from the paraview
from paraview.simple import *
#### disable automatic camera reset on 'Show'
# create a new 'Legacy VTK Reader'
ssm_ts_uv_001 = LegacyVTKReader(registrationName='ssm_ts_uv_001*', FileNames="""'
output\\ssm_ts_uv_00134.vtk', '
output\\ssm_ts_uv_00135.vtk', '
output\\ssm_ts_uv_00136.vtk', '
output\\ssm_ts_uv_00137.vtk', '
output\\ssm_ts_uv_00138.vtk', '
output\\ssm_ts_uv_00139.vtk', '
output\\ssm_ts_uv_00140.vtk', '
output\\ssm_ts_uv_00141.vtk', '
output\\ssm_ts_uv_00142.vtk', '
output\\ssm_ts_uv_00143.vtk', '
output\\ssm_ts_uv_00144.vtk', '
output\\ssm_ts_uv_00145.vtk', '
output\\ssm_ts_uv_00146.vtk', '
output\\ssm_ts_uv_00147.vtk', '
output\\ssm_ts_uv_00148.vtk', '
output\\ssm_ts_uv_00149.vtk', '
output\\ssm_ts_uv_00150.vtk', '
output\\ssm_ts_uv_00151.vtk', '
output\\ssm_ts_uv_00152.vtk', '
output\\ssm_ts_uv_00153.vtk', '
output\\ssm_ts_uv_00154.vtk', '
output\\ssm_ts_uv_00155.vtk', '
output\\ssm_ts_uv_00156.vtk', '
output\\ssm_ts_uv_00157.vtk', '
output\\ssm_ts_uv_00158.vtk', '
output\\ssm_ts_uv_00159.vtk', '
output\\ssm_ts_uv_00160.vtk', '
output\\ssm_ts_uv_00161.vtk', '
output\\ssm_ts_uv_00162.vtk', '
output\\ssm_ts_uv_00163.vtk', '
output\\ssm_ts_uv_00164.vtk', '
output\\ssm_ts_uv_00165.vtk', '
output\\ssm_ts_uv_00166.vtk', '
output\\ssm_ts_uv_00167.vtk', '
output\\ssm_ts_uv_00168.vtk', '
output\\ssm_ts_uv_00169.vtk', '
output\\ssm_ts_uv_00170.vtk'""")
( 60.189s) [paraview ] vtkPDataSetReader.cxx:668 ERR| vtkPDataSetReader (000001EBBCF85CD0): Initialize: Could not open file 'output\ssm_ts_uv_00134.vtk', 'output\ssm_ts_uv_00135.vtk', 'output\ssm_ts_uv_00136.vtk', 'output\ssm_ts_uv_00137.vtk', 'output\ssm_ts_uv_00138.vtk', 'output\ssm_ts_uv_00139.vtk', 'output\ssm_ts_uv_00140.vtk', 'output\ssm_ts_uv_00141.vtk', 'output\ssm_ts_uv_00142.vtk', 'output\ssm_ts_uv_00143.vtk', 'output\ssm_ts_uv_00144.vtk', 'output\ssm_ts_uv_00145.vtk', 'output\ssm_ts_uv_00146.vtk', 'output\ssm_ts_uv_00147.vtk', 'output\ssm_ts_uv_00148.vtk', 'output\ssm_ts_uv_00149.vtk', 'output\ssm_ts_uv_00150.vtk', 'output\ssm_ts_uv_00151.vtk', 'output\ssm_ts_uv_00152.vtk', 'output\ssm_ts_uv_00153.vtk', 'output\ssm_ts_uv_00154.vtk', 'output\ssm_ts_uv_00155.vtk', 'output\ssm_ts_uv_00156.vtk', 'output\ssm_ts_uv_00157.vtk', 'output\ssm_ts_uv_00158.vtk', 'output\ssm_ts_uv_00159.vtk', 'output\ssm_ts_uv_00160.vtk', 'output\ssm_ts_uv_00161.vtk', 'output\ssm_ts_uv_00162.vtk', 'output\ssm_ts_uv_00163.vtk', 'output\ssm_ts_uv_00164.vtk', 'output\ssm_ts_uv_00165.vtk', 'output\ssm_ts_uv_00166.vtk', 'output\ssm_ts_uv_00167.vtk', 'output\ssm_ts_uv_00168.vtk', 'output\ssm_ts_uv_00169.vtk', 'output\ssm_ts_uv_00170.vtk'
( 60.190s) [paraview ] vtkExecutive.cxx:753 ERR| vtkPVCompositeDataPipeline (000001EBBD2C3270): Algorithm vtkFileSeriesReader(000001EBBCE3CD10) returned failure for request: vtkInformation (000001EBBB5AD520)
Debug: Off
Modified Time: 111671
Reference Count: 1
Registered Events: (none)
Request: REQUEST_DATA_OBJECT
FORWARD_DIRECTION: 0
ALGORITHM_AFTER_FORWARD: 1
