Hello everyone,
I have a problem with the calculator, although I put the “” in my text. Is it a problem with the values?
The field 7 has the interval [3;11], can I change the intervals in the calculator?
Thank you for your help.
Pauline
Hello everyone,
Pauline
Please share your data.
How to display the field 7 on "Layout ?
iHat*"Field 7" + jHat*"Field 4" + kHat*"Field 7" calculator expression works great.
Which version of ParaView are you using ? on which OS ?
5.5.2.556 64-bit
This is very old, please update: https://www.paraview.org/download/
ok, but is it possible to display just the field 7 on the “CAD” ?
What is the CAD ?
“Render view” sorry
Have you a idea ?
You probably want to use TableToPoints.
No I use Glyph but he scale is not displayed, because I think calculator is not working
You will have to provide more details and explanations if you want more help.
Please update first.
there was an error in the script.
Thank you for your help!
