I tried to follow instructions in ParaView Web documentations which in here :
But after tried to build the web app I get the following error messages :
0 info it worked if it ends with ok
1 verbose cli [ ‘/home/tjggisapp/.nvm/versions/node/v4.9.1/bin/node’,
1 verbose cli   ‘/home/tjggisapp/.nvm/versions/node/v4.9.1/bin/npm’,
1 verbose cli   ‘run’,
1 verbose cli   ‘build’ ]
2 info using npm@2.15.11
3 info using node@v4.9.1
4 verbose run-script [ ‘prebuild’, ‘build’, ‘postbuild’ ]
5 info prebuild paraviewweb@0.0.0-semantically-release
6 info build paraviewweb@0.0.0-semantically-release
7 verbose unsafe-perm in lifecycle true
8 info paraviewweb@0.0.0-semantically-release Failed to exec build script
9 verbose stack Error: paraviewweb@0.0.0-semantically-release build: webpack --progress --colors --mode development --devtool source-map
9 verbose stack Exit status 1
9 verbose stack     at EventEmitter. (/home/tjggisapp/.nvm/versions/node/v4.9.1/lib/node_modules/npm/lib/utils/lifecycle.js:217:16)
9 verbose stack     at emitTwo (events.js:87:13)
9 verbose stack     at EventEmitter.emit (events.js:172:7)
9 verbose stack     at ChildProcess. (/home/tjggisapp/.nvm/versions/node/v4.9.1/lib/node_modules/npm/lib/utils/spawn.js:24:14)
9 verbose stack     at ChildProcess.emit (events.js:172:7)
9 verbose stack     at maybeClose (internal/child_process.js:862:16)
9 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:222:5)
10 verbose pkgid paraviewweb@0.0.0-semantically-release
11 verbose cwd /home/tjggisapp/paraviewweb
12 error Linux 4.15.0-70-generic
13 error argv “/home/tjggisapp/.nvm/versions/node/v4.9.1/bin/node” “/home/tjggisapp/.nvm/versions/node/v4.9.1/bin/npm” “run” “build”
14 error node v4.9.1
15 error npm  v2.15.11
16 error code ELIFECYCLE
17 error paraviewweb@0.0.0-semantically-release build: webpack --progress --colors --mode development --devtool source-map
17 error Exit status 1
18 error Failed at the paraviewweb@0.0.0-semantically-release build script ‘webpack --progress --colors --mode development --devtool source-map’.
18 error This is most likely a problem with the paraviewweb package,
18 error not with npm itself.
18 error Tell the author that this fails on your system:
18 error     webpack --progress --colors --mode development --devtool source-map
18 error You can get information on how to open an issue for this project with:
18 error     npm bugs paraviewweb
18 error Or if that isn’t available, you can get their info via:
18 error
18 error     npm owner ls paraviewweb
18 error There is likely additional logging output above.
19 verbose exit [ 1, true ]
I tried to install it with Ubuntu Server 18.04 but still get same error. Could any body help me to solve this error?
