I am using Paraview to visualize a CGNS file which was generated by one of the test examples in the CGNS github. It gives an error “Mixed definition of unstructured zone by elements and by faces is not valid”. Here is the link to the cgns file.
The Paraview reported error seems clear. You can’t mixed ngon/nface with classical unstructured elements. Thanks for pointing out the cgns github file that is not up to date.
Thanks for the reply, Mickael! That is very useful to know.
Hi Mickaël,
We have not found anything in the CGNS documentation that indicates that ngons and canonical elements must but separated. Could you refer us to such document or explain how the standard does not allow for it?
Many thanks,
Alexandre
Hello, what is your use case ?
Indeed the standard does not prevent you from using both in the same zone. But, it isconvenient for ParaView reader to assume that we are not mixing the two worlds.
Thanks for your answer. We are working on some internal mesh reorganization and are considering our options, so no finished use case yet. Compatibility with existing readers is one of the elements we are taking into account.
I checked the source recently and I think the reader has loosen its requirements. You can now have separate classical elements + Ngon but still no MIXED element sections.
