CapLek
(Oleh)
1
Hi all,
Trying to run kitware/paraview:pv-v5.8.0-egl-py3 image in docker using following command
docker run --gpus all -ti kitware/paraview:pv-v5.8.0-egl-py3
But when I`m starting pvpython process after checking GL information I’ve got segfault
$ ./bin/pvpython --force-offscreen-rendering
Python 3.6.9 (default, Nov 7 2019, 10:44:02)
[GCC 8.3.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> from paraview.simple import *
>>> print(GetOpenGLInformation().GetCapabilities())
( 18.568s) [main thread ] vtkEGLRenderWindow.cxx:311 WARN| vtkEGLRenderWindow (0x55e542b7d7c0): Setting an EGL display to device index: 0 require EGL_EXT_device_base EGL_EXT_platform_device EGL_EXT_platform_base extensions
( 18.568s) [main thread ] vtkEGLRenderWindow.cxx:382 ERR| vtkEGLRenderWindow (0x55e542b7d7c0): Only EGL 1.4 and greater allows OpenGL as client API. See eglBindAPI for more information.
( 18.569s) [main thread ]vtkOpenGLRenderWindow.c:565 ERR| vtkEGLRenderWindow (0x55e542b7d7c0): GLEW could not be initialized: Missing GL version
Loguru caught a signal: SIGSEGV
Stack trace:
0 0x7f7371290f20 /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20) [0x7f7371290f20]
( 18.569s) [main thread ] :0 FATL| Signal: SIGSEGV
Segmentation fault
The host machine is Windows 10 21H2, graphics card RTX 3050 NVIDIA card with 511.65 driver version.
What am I missing?
Thanks.
jourdain
(Sebastien Jourdain)
2
Did you try the nvidia image to validate that your runtime is properly setup?
sudo docker run --gpus all --rm nvidia/cuda:9.0-base nvidia-smi
You may want to pick a newer version of the cuda image but the idea is here.
CapLek
(Oleh)
3
My host machine is Windows. Here is output
| NVIDIA-SMI 510.47.03 Driver Version: 511.65 CUDA Version: 11.6 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce ... On | 00000000:01:00.0 Off | N/A |
| N/A 41C P5 12W / N/A | 0MiB / 4096MiB | 1% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| No running processes found |
jourdain
4
I’m not sure about the capability part but it seems that you should be good to go.
No need to do the --force-offscreen-rendering since your binary is the EGL one.
You should be able to do the following without crash in docker/pvpython
Cone()
Show()
Render()
jourdain
6
Since the “latest” nvidia image is working for you, can you build one where you download/untar pv egl and use it?
Taking a binary from here and doing something like that but with a local file rather than downloading it?
