(  10.639s) [paraview        ]vtkOSPRayMaterialLibrar:280    ERR| vtkOSPRayMaterialLibrary (0x141469e0): JSON parsing error: * Line 1, Column 1
Syntax error: value, object or array expected.
(  11.603s) [paraview        ]      VisRTXBackend.cxx:42    WARN| VisRTX Error: Unsupported device
(  11.607s) [paraview        ]   vtkPVSessionCore.cxx:372    ERR| vtkPVSessionCore (0x15192ca0): Object type: vtkTextProperty, could not find requested method: “SetCellOffset”
or the method was called with incorrect arguments.
while processing
Message 0 = Invoke
Argument 0 = vtk_object_pointer {vtkTextProperty (0x2175a50)}
Argument 1 = string_value {SetCellOffset}
Argument 2 = int32_value {0}
(  11.608s) [paraview        ]   vtkPVSessionCore.cxx:373    ERR| vtkPVSessionCore (0x15192ca0): Aborting execution for debugging purposes.
############ ABORT #############
(  11.608s) [paraview        ]         vtkSIProxy.cxx:621    ERR| vtkSIProxy (0x2175950): Could not parse property: CellOffset
(  11.608s) [paraview        ]   vtkPVSessionCore.cxx:372    ERR| vtkPVSessionCore (0x15192ca0): Object type: vtkTextProperty, could not find requested method: “SetCellOffset”
while processing
Message 0 = Invoke
(  11.609s) [paraview        ]         vtkSIProxy.cxx:621    ERR| vtkSIProxy (0x1517dfa0): Could not parse property: CellOffset
(  11.609s) [paraview        ]   vtkPVSessionCore.cxx:372    ERR| vtkPVSessionCore (0x15192ca0): Object type: vtkTextProperty, could not find requested method: “SetCellOffset”
while processing
Message 0 = Invoke
(  11.609s) [paraview        ]   vtkPVSessionCore.cxx:373    ERR| vtkPVSessionCore (0x15192ca0): Aborting execution for debugging purposes.
(  11.609s) [paraview        ]         vtkSIProxy.cxx:621    ERR| vtkSIProxy (0x2177d50): Could not parse property: CellOffset
(  11.610s) [paraview        ]   vtkPVSessionCore.cxx:372    ERR| vtkPVSessionCore (0x15192ca0): Object type: vtkTextProperty, could not find requested method: “SetCellOffset”
while processing
Message 0 = Invoke
(  11.610s) [paraview        ]   vtkPVSessionCore.cxx:373    ERR| vtkPVSessionCore (0x15192ca0): Aborting execution for debugging purposes.
(  11.610s) [paraview        ]         vtkSIProxy.cxx:621    ERR| vtkSIProxy (0x23ab7a0): Could not parse property: CellOffset
while processing
Message 0 = Invoke
(  11.611s) [paraview        ]   vtkPVSessionCore.cxx:373    ERR| vtkPVSessionCore (0x15192ca0): Aborting execution for debugging purposes.
(  11.611s) [paraview        ]         vtkSIProxy.cxx:621    ERR| vtkSIProxy (0x2179060): Could not parse property: CellOffset
(  11.611s) [paraview        ]   vtkPVSessionCore.cxx:372    ERR| vtkPVSessionCore (0x15192ca0): Object type: vtkTextProperty, could not find requested method: “SetCellOffset”
while processing
Message 0 = Invoke
(  11.611s) [paraview        ]         vtkSIProxy.cxx:621    ERR| vtkSIProxy (0xda7610): Could not parse property: CellOffset
(  11.614s) [paraview        ]         vtkSIProxy.cxx:302    ERR| vtkSIProxy (0x2175950): Incorrect message received. Missing xml_group and xml_name information.
global_id: 9098
[paraview_protobuf.ProxyState.property] {
value {
type: INT
integer: 12
(  11.614s) [paraview        ]         vtkSIProxy.cxx:302    ERR| vtkSIProxy (0x1517dfa0): Incorrect message received. Missing xml_group and xml_name information.
global_id: 9099
value {
type: INT
integer: 12
(  11.615s) [paraview        ]         vtkSIProxy.cxx:302    ERR| vtkSIProxy (0x2177d50): Incorrect message received. Missing xml_group and xml_name information.
global_id: 9100
value {
type: INT
integer: 12
(  11.615s) [paraview        ]         vtkSIProxy.cxx:302    ERR| vtkSIProxy (0x23ab7a0): Incorrect message received. Missing xml_group and xml_name information.
global_id: 9101
value {
type: INT
integer: 12
(  11.615s) [paraview        ]         vtkSIProxy.cxx:302    ERR| vtkSIProxy (0x2179060): Incorrect message received. Missing xml_group and xml_name information.
global_id: 9102
value {
type: INT
integer: 12
(  11.615s) [paraview        ]         vtkSIProxy.cxx:302    ERR| vtkSIProxy (0xda7610): Incorrect message received. Missing xml_group and xml_name information.
global_id: 9103
value {
type: INT
integer: 12
(  11.616s) [paraview        ]      VisRTXBackend.cxx:42    WARN| VisRTX Error: Unsupported device
(  11.701s) [paraview        ]         vtkSIProxy.cxx:302    ERR| vtkSIProxy (0x2175950): Incorrect message received. Missing xml_group and xml_name information.
global_id: 9098
[paraview_protobuf.ProxyState.log_name]: “RenderView1/AxesGrid/GridAxes3DActor/XLabelProperties”
(  11.701s) [paraview        ]         vtkSIProxy.cxx:302    ERR| vtkSIProxy (0x1517dfa0): Incorrect message received. Missing xml_group and xml_name information.
global_id: 9099
[paraview_protobuf.ProxyState.log_name]: “RenderView1/AxesGrid/GridAxes3DActor/XTitleProperties”
(  11.702s) [paraview        ]         vtkSIProxy.cxx:302    ERR| vtkSIProxy (0x2177d50): Incorrect message received. Missing xml_group and xml_name information.
global_id: 9100
[paraview_protobuf.ProxyState.log_name]: “RenderView1/AxesGrid/GridAxes3DActor/YLabelProperties”
(  11.702s) [paraview        ]         vtkSIProxy.cxx:302    ERR| vtkSIProxy (0x23ab7a0): Incorrect message received. Missing xml_group and xml_name information.
global_id: 9101
[paraview_protobuf.ProxyState.log_name]: “RenderView1/AxesGrid/GridAxes3DActor/YTitleProperties”
(  11.702s) [paraview        ]         vtkSIProxy.cxx:302    ERR| vtkSIProxy (0x2179060): Incorrect message received. Missing xml_group and xml_name information.
global_id: 9102
[paraview_protobuf.ProxyState.log_name]: “RenderView1/AxesGrid/GridAxes3DActor/ZLabelProperties”
(  11.703s) [paraview        ]         vtkSIProxy.cxx:302    ERR| vtkSIProxy (0xda7610): Incorrect message received. Missing xml_group and xml_name information.
global_id: 9103
[paraview_protobuf.ProxyState.log_name]: “RenderView1/AxesGrid/GridAxes3DActor/ZTitleProperties”
