Hello everyone,
because I am working with large models a colleague recommended me to work with a paraview server where I can use multiple cores. I found an instruction online how to setup up paraview for working remotely which is the following:
Make sure you install the same version on the client and on the server. Then you can run on your server:
<paraview_install>/bin/mpiexec -np 4 <paraview_install>/bin/pvserver
Than you can use your client to connect to this server.
<paraview_install>bin/paraview --url=
I have to say that my server and client is the same machine. The first time I followed the instruction everything worked fine. But when I closed paraview and opened it again I got following error and it is not possible to connect to the server and work with paraview on multiple cores anymore.
Waiting for client...
Connection URL: xxx
Accepting connection(s): xxx
Connection URL: xxx
Exiting...
( 0.064s) [pvserver ] vtkSocket.cxx:187 ERR| vtkServerSocket (0x56270f1acbd0): Socket error in call to bind. Address already in use.
( 0.064s) [pvserver ]vtkTCPNetworkAccessMana:440 ERR| vtkTCPNetworkAccessManager (0x56270f0e8c90): Failed to set up server socket.
Connection URL: xxx
( 0.065s) [pvserver ] vtkSocket.cxx:187 ERR| vtkServerSocket (0x55cf1c3dac00): Socket error in call to bind. Address already in use.
( 0.065s) [pvserver ]vtkTCPNetworkAccessMana:440 ERR| vtkTCPNetworkAccessManager (0x55cf1c316c90): Failed to set up server socket.
Connection URL: xxx
Exiting...
( 0.065s) [pvserver ] vtkSocket.cxx:187 ERR| vtkServerSocket (0x55d56baafc00): Socket error in call to bind. Address already in use.
( 0.065s) [pvserver ]vtkTCPNetworkAccessMana:440 ERR| vtkTCPNetworkAccessManager (0x55d56b9ebc90): Failed to set up server socket.
Exiting...
Do I need to close my first connection? If so, how is that possible? Could somebody please help me? I appreciate any kind of help. If you need additional information, feel free to ask.
Many thanks and best regards,
Daniel
