Getting errors while build edition = CORE (CANONICAL builds fine):
[0/1] Re-running CMake... -- VTK version: 9.2.6-2818-g481a2e7785 CMake Error at CMakeLists.txt:400 (message): The following modules were requested or required, but not found: ParaView::RemotingViews;ParaView::VTKExtensionsFiltersRendering;ParaView::RemotingViews;ParaView::VTKExtensionsIOExodus;ParaView::RemotingViews;ParaView::RemotingViews;ParaView::RemotingViews;ParaView::RemotingViews;ParaView::VTKExtensionsFiltersRendering;ParaView::RemotingViews;ParaView::VTKExtensionsFiltersRendering.
-- Configuring incomplete, errors occurred!
I get these warnings at the end of my cmake command
Some of these libraries may not be found correctly.
Plugins/StereoCursorView/CMakeLists.txt:1 (paraview_add_plugin)
CMake Warning at CMake/ParaViewPlugin.cmake:1494 (add_library):
Cannot generate a safe runtime search path for target StreamingParticles
because files in some directories may conflict with libraries in implicit
directories:
runtime library [libvtkRemotingViews-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkPVVTKExtensionsFiltersRendering-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkRemotingServerManager-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkprotobuf-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkChartsCore-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkRenderingParallel-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkViewsContext2D-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkViewsCore-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkInteractionWidgets-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkRenderingAnnotation-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkjsoncpp-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkRemotingCore-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkPVVTKExtensionsCore-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkRenderingContext2D-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkParallelCore-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkIOXML-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkIOXMLParser-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkRenderingOpenGL2-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkIOImage-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkRenderingHyperTreeGrid-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkImagingCore-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkRenderingUI-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkRenderingCore-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkFiltersSources-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkFiltersGeneral-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkfmt-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkFiltersCore-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkCommonExecutionModel-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkCommonDataModel-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkCommonMisc-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkCommonTransforms-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkCommonMath-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkkissfft-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkglew-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkRemotingClientServerStream-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkCommonCore-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtksys-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
Plugins/StreamingParticles/CMakeLists.txt:1 (paraview_add_plugin)
CMake Warning at VTK/CMake/vtkModule.cmake:3705 (add_library):
Cannot generate a safe runtime search path for target vtkStreamingParticles
directories:
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
Plugins/StreamingParticles/Particles/CMakeLists.txt:6 (vtk_module_add_module)
Cannot generate a safe runtime search path for target SurfaceLIC because
directories:
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
Plugins/SurfaceLIC/CMakeLists.txt:1 (paraview_add_plugin)
Cannot generate a safe runtime search path for target ThickenLayeredCells
directories:
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
Plugins/ThickenLayeredCells/CMakeLists.txt:1 (paraview_add_plugin)
vtkThickenLayeredCellsFilters because files in some directories may
conflict with libraries in implicit directories:
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
Plugins/ThickenLayeredCells/Filters/CMakeLists.txt:4 (vtk_module_add_module)
Cannot generate a safe runtime search path for target VTKmFilters because
directories:
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
Plugins/VTKmFilters/CMakeLists.txt:1 (paraview_add_plugin)
CMake Warning at CMake/ParaViewClient.cmake:408 (add_executable):
Cannot generate a safe runtime search path for target paraview because
directories:
runtime library [libpqApplicationComponents-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkUtilitiesPythonInitializer-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libpqComponents-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libpqPython-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libpqCore-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libpqWidgets-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkqttesting-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkGUISupportQt-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
runtime library [libvtkRemotingSettings-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
runtime library [libvtkPythonInterpreter-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
runtime library [libvtkWrappingPythonCore3.9-pv5.11.1.dylib] in /Users/msa/paraview_build/lib may be hidden by files in:
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
/usr/local/lib
Clients/ParaView/CMakeLists.txt:69 (paraview_client_add)
/Users/msa/paraview/VTK/Utilities/MetaIO/vtkmetaio/metaUtils.cxx:383:7: warning: ‘sprintf’ is deprecated: This function is provided for compatibility reasons only. Due to security concerns inherent in the design of sprintf(3), it is highly recommended that you use snprintf(3) instead. [-Wdeprecated-declarations]
sprintf(&((static_cast<MET_ASCII_CHAR_TYPE *>(_data))[_index]), “%f”, _value);
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX13.1.sdk/usr/include/stdio.h:188:1: note: ‘sprintf’ has been explicitly marked deprecated here
__deprecated_msg(“This function is provided for compatibility reasons only. Due to security concerns inherent in the design of sprintf(3), it is highly recommended that you use snprintf(3) instead.”)
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX13.1.sdk/usr/include/sys/cdefs.h:215:48: note: expanded from macro ‘__deprecated_msg’ #define __deprecated_msg(_msg) attribute((deprecated(_msg)))
/Users/msa/paraview/VTK/Utilities/MetaIO/vtkmetaio/metaUtils.cxx:470:7: warning: ‘sprintf’ is deprecated: This function is provided for compatibility reasons only. Due to security concerns inherent in the design of sprintf(3), it is highly recommended that you use snprintf(3) instead. [-Wdeprecated-declarations]
sprintf(&((static_cast<MET_ASCII_CHAR_TYPE *>(_toData))[_index]), “%f”, tf);
2 warnings generated.
[5901/21263] Linking CXX shared module lib/python3.9/site-packages/vtkmodules/vtkRenderingOpenGL2.so
ld: warning: -undefined dynamic_lookup may not work with chained fixups
[5963/21263] Linking CXX shared module lib/python3.9/site-packages/vtkmodules/vtkIOLegacy.so
[6006/21263] Linking CXX shared module lib/python3.9/site-packages/vtkmodules/vtkCommonColor.so
[6007/21263] Linking CXX shared module lib/python3.9/site-packages/vtkmodules/vtkIOGeometry.so
[6037/21263] Linking CXX shared module lib/python3.9/site-packages/vtkmodules/vtkImagingSources.so
[6068/21263] Linking CXX shared module lib/python3.9/site-packages/vtkmodules/vtkParallelCore.so
[6108/21263] Linking CXX shared module lib/python3.9/site-packages/vtkmodules/vtkImagingColor.so
[6161/21263] Linking CXX shared module lib/python3.9/site-packages/vtkmodules/vtkRenderingAnnotation.so
[6192/21263] Linking CXX shared module lib/python3.9/site-packages/vtkmodules/vtkInteractionStyle.so
[6252/21263] Linking CXX shared module lib/python3.9/site-packages/vtkmodules/vtkImagingHybrid.so
[6293/21263] Linking CXX shared module lib/python3.9/site-packages/vtkmodules/vtkFiltersModeling.so
