I created a vtr file to visualize with paraview , but when I am opening it in paraview , the following errors are coming in output messages section:
ERROR: In /home/buildslave/dashboards/buildbot/paraview-pvbinsdash-linux-shared-release_superbuild/build/superbuild/paraview/src/VTK/IO/XML/vtkXMLStructuredDataReader.cxx, line 360
vtkXMLRectilinearGridReader (0x7206460): Error reading extent 0 139 0 139 0 139 from piece 0
ERROR: In /home/buildslave/dashboards/buildbot/paraview-pvbinsdash-linux-shared-release_superbuild/build/superbuild/paraview/src/VTK/IO/XML/vtkXMLDataReader.cxx, line 415
vtkXMLRectilinearGridReader (0x7206460): Cannot read point data array "energy" from PointData in piece 0. The data array in the element may be too short.
Thanks for your earlier reply. Please find the vtr file attached alongwith. Also find attached alongwith the python script I am using to create the file and the required files.
I have attached new file which is in Mbs now. I am only able to see grid whereas I also want to see two other properties. Could you please check this , why I am only getting the grid and not the properties inside the grid.
I am a graduate student at Harbin Engineering University.I recently encountered the same problem in the process of learning the software. How do you solve it?Is it convenient to tell me?
Thanks.
