I am seeing the an error whenever I use surface LIC. I am using paraview 5.4.1.
Initially,
When I load my case file and click “Apply”, I see an error message
[ERROR: In :\bbd\2d618e80\build\superbuild\paraview\src\VTK\IO\EnSight\vtkEnSightGoldBinaryReader.cxx, line 2267
vtkEnSightGoldBinaryReader (0000023852A76A20): Unknown element type "coordinates "].
In the selection dropdown list I am seeing velocity as "velocity(“partial”). But everything after this looks as expected.
Later when I load surfaceLIC, I see the message paraview error.txt (5.4 KB).
in short, it shows a failing shader and then :
ERROR: In C:\bbd\2d618e80\build\superbuild\paraview\src\VTK\Rendering\OpenGL2\vtkShaderProgram.cxx, line 424
vtkShaderProgram (00000238B4095460): ERROR: 0:151: 'normalVCVSOutput' : undeclared identifier
ERROR: 0:151: '=' : cannot convert from 'highp float' to '3-component vector of highp float'
How can I fix this error?
