I am trying to build ParaView. I am using :
- cmake 3.8.2
- HDF5 1.8.18
- Qt 5.10.1
using the following cmake line :
cmake /dev/shm/mboisson/avx2/ParaView/5.5.2/gompi-2016.4.11/ParaView-v5.5.2/ -DCMAKE_INSTALL_PREFIX=/home/mboisson/.local/easybuild/software/2017/avx2/MPI/gcc5.4/openmpi2.1/paraview/5.5.2 -DCMAKE_C_COMPILER=‘mpicc’ -DCMAKE_Fortran_FLAGS=’-O2 -ftree-vectorize -march=core-avx2 -fno-math-errno -fPIC’ -DCMAKE_CXX_FLAGS=’-O2 -ftree-vectorize -march=core-avx2 -fno-math-errno -fPIC’ -DCMAKE_CXX_COMPILER=‘mpicxx’ -DCMAKE_Fortran_COMPILER=‘mpifort’ -DCMAKE_C_FLAGS=’-O2 -ftree-vectorize -march=core-avx2 -fno-math-errno -fPIC’ -DCMAKE_VERBOSE_MAKEFILE=ON -DCMAKE_SKIP_RPATH=ON -DPARAVIEW_INSTALL_DEVELOPMENT_FILES=ON -DVTK_OPENGL_HAS_OSMESA=ON -DPARAVIEW_USE_MPI=ON -DPARAVIEW_QT_VERSION=5 -DQT_QMAKE_EXECUTABLE=$EBROOTQT5/bin/qmake -DQt5_DIR=$EBROOTQT5/lib/cmake/Qt5 -DPARAVIEW_USE_OSPRAY=ON -DOSPRAY_INSTALL_DIR=$NIXUSER_PROFILE -DVTK_USE_SYSTEM_HDF5=ON -DPARAVIEW_ENABLE_PYTHON=ON -DBUILD_SHARED_LIBS=ON -DBUILD_TESTING=OFF -DExternalData_OBJECT_STORES=/dev/shm/mboisson/avx2/ParaView/5.5.2/gompi-2016.4.11/ExternalData
cmake works fine. However, it fails at the make step, with :
cd /dev/shm/mboisson/avx2/ParaView/5.5.2/gompi-2016.4.11/easybuild_obj/Wrapping/ClientServer && ../../bin/vtkWrapClientServer-pv5.5 @/dev/shm/mboisson/avx2/ParaView/5.5.2/gompi-2016.4.11/easybuild_obj/Wrapping/ClientServer/vtkRenderingCoreCS.args -o /dev/shm/mboisson/avx2/ParaView/5.5.2/gompi-2016.4.11/easybuild_obj/Wrapping/ClientServer/vtkPointPickerClientServ
er.cxx /dev/shm/mboisson/avx2/ParaView/5.5.2/gompi-2016.4.11/ParaView-v5.5.2/VTK/Rendering/Core/vtkPointPicker.h
In file included from /cvmfs/soft.computecanada.ca/easybuild/software/2017/Core/qt/5.10.1/include/QtWidgets/QApplication:1:0,
from /dev/shm/mboisson/avx2/ParaView/5.5.2/gompi-2016.4.11/ParaView-v5.5.2/VTK/GUISupport/Qt/QVTKApplication.h:38,
from /dev/shm/mboisson/avx2/ParaView/5.5.2/gompi-2016.4.11/ParaView-v5.5.2/VTK/GUISupport/Qt/QVTKApplication.cxx:15:
/cvmfs/soft.computecanada.ca/easybuild/software/2017/Core/qt/5.10.1/include/QtWidgets/qapplication.h:79:14: error: missing binary operator before token “(”
#if QT_CONFIG(wheelevent)
/cvmfs/soft.computecanada.ca/easybuild/software/2017/Core/qt/5.10.1/include/QtWidgets/qapplication.h:157:14: error: missing binary operator before token “(”
[ 43%] CS Wrapping - generating vtkRenderedAreaPickerClientServer.cxx
cd /dev/shm/mboisson/avx2/ParaView/5.5.2/gompi-2016.4.11/easybuild_obj/Wrapping/ClientServer && …/…/bin/vtkWrapClientServer-pv5.5 @/dev/shm/mboisson/avx2/ParaView/5.5.2/gompi-2016.4.11/easybuild_obj/Wrapping/ClientServer/vtkRenderingCoreCS.args -o /dev/shm/mboisson/avx2/ParaView/5.5.2/gompi-2016.4.11/easybuild_obj/Wrapping/ClientServer/vtkRenderedAreaPickerClientServer.cxx /dev/shm/mboisson/avx2/ParaView/5.5.2/gompi-2016.4.11/ParaView-v5.5.2/VTK/Rendering/Core/vtkRenderedAreaPicker.h
In file included from /cvmfs/soft.computecanada.ca/easybuild/software/2017/Core/qt/5.10.1/include/QtCore/QTimer:1:0,
from /dev/shm/mboisson/avx2/ParaView/5.5.2/gompi-2016.4.11/ParaView-v5.5.2/VTK/GUISupport/Qt/QVTKInteractorAdapter.cxx:40:
/cvmfs/soft.computecanada.ca/easybuild/software/2017/Core/qt/5.10.1/include/QtCore/qtimer.h:50:19: error: missing binary operator before token “(”
#if QT_HAS_INCLUDE()
/cvmfs/soft.computecanada.ca/easybuild/software/2017/Core/qt/5.10.1/include/QtCore/qtimer.h:167:19: error: missing binary operator before token “(”
#if QT_HAS_INCLUDE() || defined(Q_QDOC)
/cvmfs/soft.computecanada.ca/easybuild/software/2017/Core/qt/5.10.1/include/QtCore/qtimer.h:213:19: error: missing binary operator before token “(”
[ 43%] CS Wrapping - generating vtkScenePickerClientServer.cxx
cd /dev/shm/mboisson/avx2/ParaView/5.5.2/gompi-2016.4.11/easybuild_obj/Wrapping/ClientServer && …/…/bin/vtkWrapClientServer-pv5.5 @/dev/shm/mboisson/avx2/ParaView/5.5.2/gompi-2016.4.11/easybuild_obj/Wrapping/ClientServer/vtkRenderingCoreCS.args -o /dev/shm/mboisson/avx2/ParaView/5.5.2/gompi-2016.4.11/easybuild_obj/Wrapping/ClientServer/vtkScenePickerClientServer.cxx /dev/shm/mboisson/avx2/ParaView/5.5.2/gompi-2016.4.11/ParaView-v5.5.2/VTK/Rendering/Core/vtkScenePicker.h
In file included from /cvmfs/soft.computecanada.ca/easybuild/software/2017/Core/qt/5.10.1/include/QtGui/QResizeEvent:1:0,
from /dev/shm/mboisson/avx2/ParaView/5.5.2/gompi-2016.4.11/ParaView-v5.5.2/VTK/GUISupport/Qt/QVTKInteractorAdapter.cxx:41:
/cvmfs/soft.computecanada.ca/easybuild/software/2017/Core/qt/5.10.1/include/QtGui/qevent.h:172:14: error: missing binary operator before token “(”
/cvmfs/soft.computecanada.ca/easybuild/software/2017/Core/qt/5.10.1/include/QtGui/qevent.h:240:14: error: missing binary operator before token “(”
#if QT_CONFIG(tabletevent)
/cvmfs/soft.computecanada.ca/easybuild/software/2017/Core/qt/5.10.1/include/QtGui/qevent.h:709:14: error: missing binary operator before token “(”
#if QT_CONFIG(whatsthis)
Any ideas ?
