Hi
I have installed system paraview 4.4 which is available in the centos 7 repository. I have installed that because the Paraview 5.4 which comes with OpenFoam 6 has installation issues and I am not able to install that on centos 7.
Now, when I open a result file, I get thiss error:
ERROR: In /builddir/build/BUILD/ParaView-v4.4.0-source/VTK/IO/Geometry/vtkOpenFOAMReader.cxx, line 4674
vtkOpenFOAMReaderPrivate (0x392d840): Error reading line 169 of /home/mahmood/OpenFOAM/mahmood-6/run/S8010-Same1-2/constant/polyMesh/faces: Expected punctuation token ')', found ~
ERROR: In /builddir/build/BUILD/ParaView-v4.4.0-source/VTK/Common/ExecutionModel/vtkExecutive.cxx, line 784
vtkPVCompositeDataPipeline (0x3932530): Algorithm vtkPOpenFOAMReader(0x3921520) returned failure for request: vtkInformation (0x3fe9b50)
Debug: Off
Modified Time: 169270
Reference Count: 1
Registered Events: (none)
Request: REQUEST_DATA
FROM_OUTPUT_PORT: 0
ALGORITHM_AFTER_FORWARD: 1
FORWARD_DIRECTION: 0
The file at constant/polyMesh/faces is a 1.3GB binary file. I don’t know if this is a compatibility issue or what. I mean maybe the file is not compatible with paraview 4.4 and I must use 5.4 or so.
َAny idea about that?
