I tried following the example with multiple inputs - vtkLandmarkRegistrationFilter which is perfect because this is actually one of the filters I’d like to use. The problem is that this causes the application to crash.
Steps:
copy the xml from the webpage and save as .xml
Tools->Manage Pulgins-> Load New → file I just saved
So far so good
type lmReg = LandmarkTransformFilter() into shell , hit enter and it crashes
Hmm. It looks like that class never existed (at least in the VTK repository). I wonder if it is missing some references from elsewhere. The vtkLandmarkTransform class is missing a SourceDataSet though, so it’s not quite that easy.
I should have mentioned that I changed the class as follows:
class=“vtkLandmarkTransform”
Looking at the error logs, I see:
( 50.101s) [paraview ]vtkPVAlgorithmPortsInfo:55 ERR| . vtkPVAlgorithmPortsInformation (0000023256E3C580): Could not downcast vtkAlgorithm.
