Extract Block Filter: Extract Single DataSet not MultiBlockDataSet
Is there a way to extract a single block from a multi-block dataset using the Extract Block filter?
Whenever I use the Extract Block filter, it returns a multi-block dataset but I need to apply filters that cannot handle multi-block datasets.
I think the best you can do right now is to use the Extract Block filter to get the block you want and then use a Merge Blocks filter to make that into a single unstructured grid. Otherwise, a Programmable Filter is probably your best bet to do the extraction in a single shot.
We shoud modify ExtractBlock to actually extract the block when a single block is selected.
https://gitlab.kitware.com/paraview/paraview/issues/18834.
Andy, want to add your tag to it?
