Extract points near extracted cell
I have a mesh with information of the cell centers.
I have a .vtk file with information on the face centers. These are displayed as gaussian points.
I would like to extract one cell of the domain and get the corresponding face information.
How can I do that? Is there a way to extract closest points to a certain geometry (extracted cell)?
Hi @Chica_ron !
You may want to look to a similar problem described here . The last post contains a script that extracts all cells around a point. You should be able to adapt it for your case.
I will take a look into it. Thanks!
I am kind of lost in this.
I understand what the script should do:
Ask the user for a mesh input and points input:
Ask for a list of cell_id’s
Loop through each cell ID and check which points are inside/on the border of cell from in points input.
Isolate the points together with the cell.
import vtk
from vtkmodules.vtkCommonDataModel import vtkDataSet
from vtkmodules.util.vtkAlgorithm import VTKPythonAlgorithmBase
from paraview.util.vtkAlgorithm import smproxy, smproperty
@smproxy.filter(label="Extract Points Inside Cells")
@smproperty.input(name="Mesh Input")
@smproperty.input(name="Points Input")
class ExtractPointsInsideCells(VTKPythonAlgorithmBase):
    def __init__(self):
        VTKPythonAlgorithmBase.__init__(self, outputType='vtkUnstructuredGrid')
        self.cell_ids = set()
        mesh_input = vtkDataSet.GetData(inInfo[0])
        # points_input = vtkDataSet.GetData(inInfo[1]) This gives an error
        return 1
    def processGrid(self, ug):
        # this routine is not working
        allCellIdsList = vtk.vtkIdList()
        for pointId in self.points:
            cellIdsList = vtk.vtkIdList()
            ug.GetPointCells(pointId, cellIdsList)
            for i in range(cellIdsList.GetNumberOfIds()):
                allCellIdsList.InsertNextId(cellIdsList.GetId(i))
        # extract all cells into a separate grid
        extract = vtk.vtkExtractCells()
        extract.SetInputData(ug)
        extract.SetCellList(allCellIdsList)
        extract.Update()
        return extract.GetOutput()
    @smproperty.intvector(name="Cell ID", default_values=0)
    def SetCellIDs(self, cell_ids_str):
        self.cell_ids = []
        if cell_ids_str:
            self.cell_ids = [int(cell_id) for cell_id in cell_ids_str.split(',')]
        self.Modified()
Question:
How can I get points_input from in_info?
Does paraview have any routine given the cell ID to collect the associated points and check if another point is inside the cell?
How can I print variables inside these functions. The print(var)does not appear to work
