I am searching for a way to select a part of my data. I have a dataset that consists of a small geometry (has volume) enclosed by a cylindrical boundary surface (hollow aside from the small geometry inside). I want to select only the internal geometry.
In the ParaView GUI, using Select Cells On, I manually select the boundary cells, rotate the render view, and repeatedly add to the current selection until all boundary cells are selected. Then I click Find Data > Invert selection so that only the small geometry/volume inside is selected.
I get this error. I know I am probably assigning the IntersectWith property incorrectly, but I do not know the correct syntax. What is the right way to do it?
