Extracting stream-wise (U_x) and span-wise(U_y) velocities from a specified sub-domain
Hello everyone,
I’ve done 3D actuator disk simulation in OpenFoam, and now I’m trying to extract some data. I need to get the velocity components in a particular subdomain, not in the full domain. The attached figure is for reference. Moreover, I know there will be thousands of points in the particular subdomain I mentioned, but I just need to find velocities at only 64 uniformly distributed points.
Question 1: How can I do that?
Question 2:
I have the VTK files for each of my simulations. Is there any way that I can convert my VTK files to a nummpy array and get the data for a particular plane and for a subdomain?
Anyone have some suggestions?
Use Clip filter or Selection filters ?
Hello Mathieu,
I’ve extracted my u and v component velocities for that specified zone. Now, I found something unusual: for the same x-grid point, four (4) y-grid points are shown in my extracted data, and their corresponding u and v velocities are also different. For example, (385.875, 406.98), this point appears four times, and their corresponding U_x and U_y velocities are also different. Any comment on this? How can I solve this issue?
Please share a screenshot ?
This is the screenshot. Sometimes I find that for a particular x-axis value, the y-axis value is repeated 3/4 times. And their U_x and U_y values are also different.
I have no idea what I’m seeing here.
You say:
To me it means that points got duplicated somehow.
Please share data and exacts steps to reproduce.
I have added my CSV file here.
Velocity_data_8_ms_3.57_deg.csv (2.6 MB)
The code I have used here is:
    import vtk
    import os
    import numpy as np
    import pandas as pd
    from vtk.util.numpy_support import vtk_to_numpy
    def extract_data_within_range(vtk_data, min_range, max_range, axes):
        all_velocity_data = np.array([]).reshape(0, 2)
        all_axes_values = np.array([]).reshape(0, 2)
        for block_id in range(vtk_data.GetNumberOfBlocks()):
            block = vtk_data.GetBlock(block_id)
            if block.IsA('vtkUnstructuredGrid'):
                point_data = block.GetPointData()
                if point_data.GetArray('U') is not None:
                    velocity_data = vtk_to_numpy(point_data.GetArray('U'))
                    point_coordinates = vtk_to_numpy(block.GetPoints().GetData())
                    indices = np.all((min_range <= point_coordinates) & (point_coordinates <= max_range), axis=1)
                    # Extracting velocity data for the selected points
                    velocity_data = velocity_data[indices, :2]  # Excluded U_z values
                    # Filter out 0 and negative values for U_x
                    mask = (velocity_data[:, 0] > 0) & (1 <= velocity_data[:, 0]) & (velocity_data[:, 0] <= 8)
                    velocity_data = velocity_data[mask]
                    # Extracting corresponding axis values
                    axis_values = point_coordinates[indices][:, axes][mask]
                    # Concatenated velocity data and axis values to the global arrays
                    all_velocity_data = np.vstack([all_velocity_data, velocity_data])
                    all_axes_values = np.vstack([all_axes_values, axis_values])
        return all_velocity_data, all_axes_values
    vtk_parent_folder = 'C:/Users/Nafiz375/openfoam_inputs/'
    for folder_name in os.listdir(vtk_parent_folder):
        # Constructing the full path to the current folder
        folder_path = os.path.join(vtk_parent_folder, folder_name)
        if os.path.isdir(folder_path):
            # Initialize empty arrays for the current folder
            folder_velocity_data = np.array([]).reshape(0, 2)
            folder_axes_values = np.array([]).reshape(0, 2)
            # Iterating through all files in the current folder
            for root, dirs, files in os.walk(folder_path):
                # Filter for .vtm files
                vtm_files = [f for f in files if f.endswith('.vtm')]
                # Iterating through each .vtm file in the current directory
                for vtm_file in vtm_files:
                    # Construct the full path to the current file
                    vtm_file_path = os.path.join(root, vtm_file)
                    # Creating a reader for the VTM file
                    reader = vtk.vtkXMLMultiBlockDataReader()
                    reader.SetFileName(vtm_file_path)
                    # Read the data
                    reader.Update()
                    # Get the output data
                    vtk_data = reader.GetOutput()
                    if vtk_data is not None:
                        # Extracting data within the specified range along the x-axis and y-axis
                        velocity_data, axes_values = extract_data_within_range(vtk_data, np.array([378, 283.5, 535.5]), np.array([1008, 787.5, 535.5]), axes=(0, 1))
                        # Concatenating velocity data and axis values to the folder arrays
                        folder_velocity_data = np.vstack([folder_velocity_data, velocity_data])
                        folder_axes_values = np.vstack([folder_axes_values, axes_values])
            # Concatenating folder arrays to the global arrays
            all_velocity_data = np.vstack([all_velocity_data, folder_velocity_data])
            all_axes_values = np.vstack([all_axes_values, folder_axes_values])
            # Converting the folder arrays to a Pandas DataFrame
            folder_df = pd.DataFrame(folder_velocity_data, columns=['U_x', 'U_y'])
            folder_df['x'] = folder_axes_values[:, 0]
            folder_df['y'] = folder_axes_values[:, 1]
            # Saving the folder DataFrame to a CSV file
            csv_file_path = f'D:/Velocity_data_{folder_name}.csv'
            folder_df.to_csv(csv_file_path, index=False)
            print(f"Filtered velocity data along x-axis and y-axis for {folder_name} has been saved to {csv_file_path}.")
Any recommendations about the problem I am having?
I think it would be better to output the z-coordinate and z-component of the flow velocity as well to confirm that the flow is really two-dimensional.
This simulation is in 3D. I extracted the data from the XY plane, as mentioned above. I extracted initially to check, and its okay.
Sorry I did not read it carefully. I understood that the vtm files you are reading in the Python code above is the result on the xy plane. Is it possible to share just one of those vtm files?
Hello Kyoshimi,
I’ve uploaded one of my VTM files that is for the final iteration.
3.57_deg_1347.vtm (744 Bytes)
