Fail to build 5.12.0-RC2 with superbuild when complie QT
now I build linux version with docker image kitware/paraview:ci-superbuild-centos7-20201028, fails when compiling QT . but succeed when compiling paraview 5.9.0. anyone knows the reason?
Info: creating super cache file /home/path/superbuild/qt5/build/.qmake.super
Info: creating cache file /home/path/superbuild/qt5/build/.qmake.cache
Info: creating stash file /home/path/superbuild/qt5/build/.qmake.stash
This is the Qt Open Source Edition.
You have already accepted the terms of the Open Source license.
Running configuration tests…
Checking for machine tuple… yes
Checking for valid makespec… yes
Checking for target architecture… x86_64
Checking for SSE2 instructions… yes
Checking for AES new instructions… yes
Checking for alloca() in alloca.h… yes
Checking for SSE3 instructions… yes
Checking for SSSE3 instructions… yes
Checking for SSE4.1 instructions… yes
Checking for SSE4.2 instructions… yes
Checking for AVX instructions… yes
Checking for AVX2 instructions… yes
Checking for AVX512 F instructions… yes
Checking for AVX512 BW instructions… yes
Checking for AVX512 CD instructions… yes
Checking for AVX512 DQ instructions… yes
Checking for AVX512 ER instructions… yes
Checking for AVX512 IFMA instructions… yes
Checking for AVX512 PF instructions… yes
Checking for AVX512 VBMI instructions… yes
Checking for AVX512 VL instructions… yes
Checking for C++14 support… yes
Checking for C++17 support… yes
Checking for C99 support… yes
Checking for C11 support… yes
Checking for pkg-config… yes
Checking for dlopen()… yes
Checking for new dtags support… yes
Checking for F16C instructions… yes
Checking for D-Bus >= 1.2 (host)… yes
Checking for Support for Intel Control-flow Enforcement Technology… no
Checking for udev… no
Checking for POSIX fallocate()… yes
Checking for precompiled header support… yes
Checking for RDRAND instruction… yes
Checking for RDSEED instruction… no
Checking for symbol visibility support… yes
Checking for -Bsymbolic-functions support… yes
Checking for SHA new instructions… yes
Checking for Signaling NaN for doubles… yes
Checking for STL compatibility… yes
Checking for zlib… yes
Checking for Intrinsics without -mXXX argument… yes
Checking for clock_gettime()… yes
Checking for POSIX monotonic clock… yes
Checking for C++11 … yes
Checking for eventfd… yes
Checking for futimens()… yes
Checking for getauxval()… yes
Checking for getentropy()… no
Checking for GLib… no
Checking for GNU libc… yes
Checking for POSIX iconv… yes
Checking for inotify… yes
Checking for SysV IPC… yes
Checking for linkat()… yes
Checking for ppoll()… yes
Checking for renameat2()… no
Checking for slog2… no
Checking for statx() in libc… no
Checking for 64 bit atomics… yes
Checking for DoubleConversion… no
Checking for O_CLOEXEC… yes
Checking for working std::atomic for function pointers… yes
Checking for getifaddrs()… yes
Checking for KRB5 GSSAPI Support… no
Checking for IPv6 ifname… yes
Checking for Linux AF_NETLINK sockets… yes
Checking for XCB >= 1.11… yes
Checking for XCB ICCCM >= 0.3.9… no
Checking for Desktop OpenGL… yes
Checking for KMS… yes
Checking for DRM Atomic API… yes
Checking for EGL… yes
Checking for XLib… yes
Checking for EGL on X11… yes
Checking for EGLDevice… yes
Checking for GBM… no
Checking for Mali EGL… no
Checking for Mali 2 EGL… no
Checking for i.Mx6 EGL… no
Checking for XCB Xlib… yes
Checking for evdev… yes
Checking for FreeType… yes
Checking for Fontconfig… yes
Checking for LinuxFB… yes
Checking for mtdev… no
Checking for OpenVG… no
Checking for default QPA platform… xcb
Checking for HarfBuzz… no
Checking for libpng… yes
Checking for libmd4c… no
Checking for tslib… no
Checking for Vulkan… no
Checking for xkbcommon >= 0.5.0… yes
Checking for xkbcommon-x11… no
Checking for CUPS… no
Checking for DB2 (IBM)… no
Checking for InterBase… no
Checking for MySQL… no
Checking for OCI (Oracle)… no
Checking for ODBC… no
Checking for PostgreSQL… no
Checking for SQLite (version 2)… no
Checking for TDS (Sybase)… no
Checking for Socket CAN… yes
Checking for Socket CAN FD… yes
Checking for 64bit pointers… yes
Checking for python… /home/path/install/bin/python
Checking for Direct3D 12… no
Checking for Assimp… no
Checking for Autodesk FBX… no
Checking for ALSA… no
Checking for GStreamer 1.0… no
Checking for GStreamer 0.10… no
Checking for Video for Linux… yes
Checking for OpenAL… no
Checking for PulseAudio >= 0.9.10… no
Checking for libresourceqt5… no
Checking for Flite… no
Checking for Speech Dispatcher… no
Checking for libclang… no
Done running configuration tests.
Configure summary:
Build type: linux-g++ (x86_64, CPU features: mmx sse sse2)
Compiler: gcc 8.3.1
Configuration: sse2 aesni sse3 ssse3 sse4_1 sse4_2 avx avx2 avx512f avx512bw avx512cd avx512dq avx512er avx512ifma avx512pf avx512vbmi avx512vl compile_examples enable_new_dtags f16c largefile precompile_header rdrnd shani x86SimdAlways shared shared rpath release c++11 c++14 c++17 c++1z concurrent reduce_exports reduce_relocations stl
Build options:
Mode … release
Optimize release build for size … no
Building shared libraries … yes
Using C standard … C11
Using C++ standard … C++17
Using ccache … no
Using new DTAGS … yes
Relocatable … yes
Using precompiled headers … yes
Using LTCG … no
Target compiler supports:
SSE … SSE2 SSE3 SSSE3 SSE4.1 SSE4.2
AVX … AVX AVX2
AVX512 … F ER CD PF DQ BW VL IFMA VBMI
Other x86 … AES F16C RDRAND SHA
Intrinsics without -mXXX option … yes
Build parts … libs tools
Qt modules and options:
Qt Concurrent … yes
Qt D-Bus … no
Qt D-Bus directly linked to libdbus … no
Qt Gui … yes
Qt Network … yes
Qt Sql … yes
Qt Testlib … yes
Qt Widgets … yes
Qt Xml … yes
Support enabled for:
Using pkg-config … yes
udev … no
Using system zlib … yes
Zstandard support … no
Qt Core:
DoubleConversion … yes
Using system DoubleConversion … no
GLib … no
iconv … yes
ICU … no
Built-in copy of the MIME database … yes
Tracing backend …
Logging backends:
journald … no
syslog … no
slog2 … no
PCRE2 … yes
Using system PCRE2 … no
Qt Network:
getifaddrs() … yes
IPv6 ifname … yes
libproxy … no
Linux AF_NETLINK … yes
OpenSSL … no
Qt directly linked to OpenSSL … no
OpenSSL 1.1 … no
DTLS … no
OCSP-stapling … no
SCTP … no
Use system proxies … yes
GSSAPI … no
Qt Gui:
Accessibility … yes
FreeType … yes
Using system FreeType … yes
HarfBuzz … yes
Using system HarfBuzz … no
Fontconfig … yes
Image formats:
GIF … yes
ICO … yes
JPEG … yes
Using system libjpeg … no
PNG … yes
Using system libpng … yes
Text formats:
HtmlParser … yes
CssParser … yes
OdfWriter … yes
MarkdownReader … yes
Using system libmd4c … no
MarkdownWriter … yes
EGL … yes
OpenVG … no
OpenGL:
Desktop OpenGL … yes
OpenGL ES 2.0 … no
OpenGL ES 3.0 … no
OpenGL ES 3.1 … no
OpenGL ES 3.2 … no
Vulkan … no
Session Management … yes
Features used by QPA backends:
evdev … yes
libinput … no
INTEGRITY HID … no
mtdev … no
tslib … no
xkbcommon … yes
X11 specific:
XLib … yes
XCB Xlib … yes
EGL on X11 … yes
xkbcommon-x11 … no
QPA backends:
DirectFB … no
EGLFS … yes
EGLFS details:
EGLFS OpenWFD … no
EGLFS i.Mx6 … no
EGLFS i.Mx6 Wayland … no
EGLFS RCAR … no
EGLFS EGLDevice … yes
EGLFS GBM … no
EGLFS VSP2 … no
EGLFS Mali … no
EGLFS Raspberry Pi … no
EGLFS X11 … yes
LinuxFB … yes
VNC … yes
Qt Sql:
SQL item models … yes
Qt Widgets:
GTK+ … no
Styles … Fusion Windows
Qt PrintSupport:
CUPS … no
Qt Sql Drivers:
DB2 (IBM) … no
InterBase … no
MySql … no
OCI (Oracle) … no
ODBC … no
PostgreSQL … no
SQLite2 … no
SQLite … yes
Using system provided SQLite … no
TDS (Sybase) … no
Qt Testlib:
Tester for item models … yes
Qt SerialBus:
Socket CAN … yes
Socket CAN FD … yes
SerialPort Support … no
Further Image Formats:
JasPer … no
MNG … no
TIFF … yes
Using system libtiff … no
WEBP … yes
Using system libwebp … no
Qt QML:
QML network support … yes
QML debugging and profiling support … yes
QML just-in-time compiler … yes
QML sequence object … yes
QML XML http request … yes
QML Locale … yes
Qt QML Models:
QML list model … yes
QML delegate model … yes
Qt Quick:
Direct3D 12 … no
AnimatedImage item … yes
Canvas item … yes
Support for Qt Quick Designer … yes
Flipable item … yes
GridView item … yes
ListView item … yes
TableView item … yes
Path support … yes
PathView item … yes
Positioner items … yes
Repeater item … yes
ShaderEffect item … yes
Sprite item … yes
QtQuick3D:
Assimp … yes
System Assimp … no
Qt Scxml:
ECMAScript data model for QtScxml … yes
Qt 3D:
Assimp … yes
System Assimp … no
Output Qt3D GL traces … no
Use SSE2 instructions … yes
Use AVX2 instructions … no
Aspects:
Render aspect … yes
Input aspect … yes
Logic aspect … yes
Animation aspect … yes
Extras aspect … yes
Qt 3D Renderers:
OpenGL Renderer … yes
RHI Renderer … no
Qt 3D GeometryLoaders:
Autodesk FBX … no
Qt Quick Controls 2:
Styles … Default Fusion Imagine Material Universal
Qt Quick Templates 2:
Hover support … yes
Multi-touch support … yes
QtXmlPatterns:
XML schema support … yes
Qt Multimedia:
ALSA … no
GStreamer 1.0 … no
GStreamer 0.10 … no
Video for Linux … yes
OpenAL … no
PulseAudio … no
Resource Policy (libresourceqt5) … no
Windows Audio Services … no
DirectShow … no
Windows Media Foundation … no
Qt TextToSpeech:
Flite … no
Flite with ALSA … no
Speech Dispatcher … no
Qt Tools:
Qt Assistant … yes
Qt Designer … yes
Qt Distance Field Generator … yes
kmap2qmap … yes
Qt Linguist … yes
Mac Deployment Tool … no
makeqpf … yes
pixeltool … yes
qdbus … yes
qev … yes
Qt Attributions Scanner … yes
qtdiag … yes
qtpaths … yes
qtplugininfo … yes
Windows deployment tool … no
WinRT Runner Tool … no
Qt Tools:
QDoc … no
Note: Also available for Linux: linux-clang linux-icc
WARNING: QDoc will not be compiled, probably because libclang could not be located. This means that you cannot build the Qt documentation.
Either ensure that llvm-config is in your PATH environment variable, or set LLVM_INSTALL_DIR to the location of your llvm installation.
On Linux systems, you may be able to install libclang by installing the libclang-dev or libclang-devel package, depending on your distribution.
On macOS, you can use Homebrew’s llvm package.
On Windows, you must set LLVM_INSTALL_DIR to the installation path.
ERROR: Feature ‘xcb’ was enabled, but the pre-condition ‘features.thread && libs.xcb && tests.xcb_syslibs && features.xkbcommon-x11’ failed.
Check config.log for details.
CMake Error at /home/path/superbuild/sb-qt5-configure.cmake:47 (message):
Failed with exit code 3
make[2]: *** [superbuild/qt5/stamp/qt5-configure] Error 1
make[1]: *** [superbuild/CMakeFiles/qt5.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs…
Building wheel for numpy (pyproject.toml): still running…
Building wheel for numpy (pyproject.toml): finished with status ‘done’
Created wheel for numpy: filename=numpy-1.25.2-cp310-cp310-linux_x86_64.whl size=26987711 sha256=191f5e5ae819730bf0fd2fdc9611deefbc971328dcbe539a2abbbd347f520ee1
Stored in directory: /tmp/pip-ephem-wheel-cache-9730kq9e/wheels/e6/1c/10/bdf6133f705a67eed29f2f8465ba9687339bc1f9d5b3b82ef4
Can you explain what you are trying to do ? Why are you trying to build ParaView 5.12.0-RC2 in one of our CI images ?
we try to comile our plugin with new paraviw version 5.12.0; the plugin is based on 5.9.0 before.When we do this job, RC2 is latest.
Do you need special option ? Kitware already provides docker images to build plugins against ParaView:
RC2 is latest.
No, 5.12.0 is latest.
thanks
Hello, I need to compile with QT, so I use the new docker kitware/paraview-for-ci:v5.12.0,but errors also exist.
[ 67%] Performing configure step for ‘qt5’
[ 67%] Performing install step for ‘pythonsetuptools’
  • cd qtbase
  • /path/superbuild/qt5/src/qtbase/configure -top-level -opensource -confirm-license -release -prefix /path/install -I /path/install/include -L /path/install/lib -skip qtconnectivity -skip qtgamepad -skip qtlocation -skip qtsensors -skip qtserialport -skip qtwayland -skip qtwebchannel -skip qtwebengine -skip qtwebsockets -nomake examples -nomake tests -no-dbus -no-icu -qt-libjpeg -qt-pcre -system-zlib -no-openssl -no-zstd -system-libpng -fontconfig -xcb -xkbcommon
    [ 68%] Built target pythontomli
    [ 69%] Built target pythonpackaging
    [ 70%] Built target pythontypingextensions
    [ 71%] Built target pythonpyparsing
    Preparing build tree…
    Creating qmake…
    make[3]: warning: jobserver unavailable: using -j1. Add ‘+’ to parent make rule.
    Done.
Processing /path/superbuild/pythonsetuptools/src
Preparing metadata (pyproject.toml): started
Preparing metadata (pyproject.toml): finished with status ‘error’
error: subprocess-exited-with-error
× Preparing metadata (pyproject.toml) did not run successfully.
│ exit code: 1
╰─> [72 lines of output]
running dist_info
creating /tmp/pip-modern-metadata-njfa46bf/setuptools.egg-info
writing /tmp/pip-modern-metadata-njfa46bf/setuptools.egg-info/PKG-INFO
writing dependency_links to /tmp/pip-modern-metadata-njfa46bf/setuptools.egg-info/dependency_links.txt
writing entry points to /tmp/pip-modern-metadata-njfa46bf/setuptools.egg-info/entry_points.txt
writing requirements to /tmp/pip-modern-metadata-njfa46bf/setuptools.egg-info/requires.txt
writing top-level names to /tmp/pip-modern-metadata-njfa46bf/setuptools.egg-info/top_level.txt
writing manifest file ‘/tmp/pip-modern-metadata-njfa46bf/setuptools.egg-info/SOURCES.txt’
reading manifest file ‘/tmp/pip-modern-metadata-njfa46bf/setuptools.egg-info/SOURCES.txt’
reading manifest template ‘MANIFEST.in’
warning: no files found matching ‘.py’ under directory ‘tests’
warning: no files found matching '
.txt’ under directory ‘docs’
warning: no files found matching ‘.conf’ under directory ‘docs’
.css’ under directory ‘docs’
warning: no files found matching ‘.css_t’ under directory ‘docs’
warning: no files found matching ‘Makefile’ under directory ‘docs’
warning: no files found matching ‘indexsidebar.html’ under directory ‘docs’
warning: no files found matching ‘msvc-build-launcher.cmd’
warning: no previously-included files matching '
.py[cod]’ found anywhere in distribution
warning: no previously-included files matching ‘pycache’ found anywhere in distribution
adding license file ‘LICENSE’
creating ‘/tmp/pip-modern-metadata-njfa46bf/setuptools-68.1.2.dist-info’
File “/path/install/lib/python3.10/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py”, line 353, in
main()
File “/path/install/lib/python3.10/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py”, line 335, in main
json_out[‘return_val’] = hook(**hook_input[‘kwargs’])
File “/path/install/lib/python3.10/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py”, line 149, in prepare_metadata_for_build_wheel
return hook(metadata_directory, config_settings)
File “/path/superbuild/pythonsetuptools/src/setuptools/build_meta.py”, line 396, in prepare_metadata_for_build_wheel
self.run_setup()
File “/path/superbuild/pythonsetuptools/src/setuptools/build_meta.py”, line 341, in run_setup
exec(code, locals())
File “”, line 92, in
File “/path/superbuild/pythonsetuptools/src/setuptools/init.py”, line 107, in setup
return distutils.core.setup(**attrs)
File “/path/superbuild/pythonsetuptools/src/setuptools/_distutils/core.py”, line 185, in setup
return run_commands(dist)
File “/path/superbuild/pythonsetuptools/src/setuptools/_distutils/core.py”, line 201, in run_commands
dist.run_commands()
File “/path/superbuild/pythonsetuptools/src/setuptools/_distutils/dist.py”, line 969, in run_commands
self.run_command(cmd)
File “/path/superbuild/pythonsetuptools/src/setuptools/dist.py”, line 1233, in run_command
super().run_command(command)
File “/path/superbuild/pythonsetuptools/src/setuptools/_distutils/dist.py”, line 988, in run_command
cmd_obj.run()
File “/path/superbuild/pythonsetuptools/src/setuptools/command/dist_info.py”, line 112, in run
bdist_wheel = self.get_finalized_command(‘bdist_wheel’)
File “/path/superbuild/pythonsetuptools/src/setuptools/_distutils/cmd.py”, line 304, in get_finalized_command
cmd_obj = self.distribution.get_command_obj(command, create)
File “/path/superbuild/pythonsetuptools/src/setuptools/_distutils/dist.py”, line 860, in get_command_obj
klass = self.get_command_class(command)
File “/path/superbuild/pythonsetuptools/src/setuptools/dist.py”, line 980, in get_command_class
self.cmdclass[command] = cmdclass = ep.load()
File “/path/install/lib/python3.10/importlib/metadata/init.py”, line 171, in load
module = import_module(match.group(‘module’))
File “/path/install/lib/python3.10/importlib/init.py”, line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 1050, in _gcd_import
File “”, line 1027, in _find_and_load
File “”, line 1006, in _find_and_load_unlocked
File “”, line 688, in _load_unlocked
File “”, line 883, in exec_module
File “”, line 241, in _call_with_frames_removed
File “/path/install/lib/python3.10/site-packages/wheel/bdist_wheel.py”, line 28, in
from .macosx_libfile import calculate_macosx_platform_tag
File “/path/install/lib/python3.10/site-packages/wheel/macosx_libfile.py”, line 43, in
import ctypes
File “/path/install/lib/python3.10/ctypes/init.py”, line 8, in
from _ctypes import Union, Structure, Array
ModuleNotFoundError: No module named ‘_ctypes’
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
error: metadata-generation-failed
× Encountered error while generating package metadata.
╰─> See above for output.
note: This is an issue with the package mentioned above, not pip.
hint: See above for details.
CMake Error at /path/superbuild/sb-pythonsetuptools-install.cmake:48 (message):
Failed with exit code 1
make[2]: *** [superbuild/CMakeFiles/pythonsetuptools.dir/build.make:101: superbuild/pythonsetuptools/stamp/pythonsetuptools-install] Error 1
make[1]: *** [CMakeFiles/Makefile2:2006: superbuild/CMakeFiles/pythonsetuptools.dir/all] Error 2
Configure summary:
Compiler: gcc 9.4.0
Configuration: sse2 aesni sse3 ssse3 sse4_1 sse4_2 avx avx2 avx512f avx512bw avx512cd avx512dq avx512er avx512ifma avx512pf avx512vbmi avx512vl compile_examples enable_new_dtags f16c largefile precompile_header rdrnd rdseed shani x86SimdAlways shared shared rpath release c++11 c++14 c++17 c++1z concurrent reduce_exports reduce_relocations stl
Build options:
Mode … release
Using ccache … no
Relocatable … yes
Using LTCG … no
AVX … AVX AVX2
Qt Concurrent … yes
Qt D-Bus … no
Qt Gui … yes
Qt Network … yes
Qt Sql … yes
Qt Testlib … yes
Qt Widgets … yes
Qt Xml … yes
udev … no
Qt Core:
GLib … no
iconv … yes
ICU … no
Tracing backend …
Logging backends:
journald … no
syslog … no
slog2 … no
PCRE2 … yes
Qt Network:
getifaddrs() … yes
IPv6 ifname … yes
libproxy … no
OpenSSL … no
OpenSSL 1.1 … no
DTLS … no
OCSP-stapling … no
SCTP … no
GSSAPI … no
Qt Gui:
Accessibility … yes
FreeType … yes
HarfBuzz … yes
Fontconfig … yes
Image formats:
GIF … yes
ICO … yes
JPEG … yes
PNG … yes
Text formats:
HtmlParser … yes
CssParser … yes
OdfWriter … yes
EGL … yes
OpenVG … no
OpenGL:
OpenGL ES 2.0 … no
OpenGL ES 3.0 … no
OpenGL ES 3.1 … no
OpenGL ES 3.2 … no
Vulkan … yes
evdev … yes
libinput … no
INTEGRITY HID … no
mtdev … no
tslib … no
xkbcommon … no
X11 specific:
XLib … yes
XCB Xlib … no
EGL on X11 … yes
xkbcommon-x11 … no
QPA backends:
DirectFB … no
EGLFS … yes
EGLFS details:
EGLFS OpenWFD … no
EGLFS i.Mx6 … no
EGLFS RCAR … no
EGLFS GBM … no
EGLFS VSP2 … no
EGLFS Mali … no
EGLFS X11 … no
LinuxFB … yes
VNC … yes
Qt Sql:
Qt Widgets:
GTK+ … no
Qt PrintSupport:
CUPS … no
Qt Sql Drivers:
DB2 (IBM) … no
InterBase … no
MySql … no
OCI (Oracle) … no
ODBC … no
PostgreSQL … no
SQLite2 … no
SQLite … yes
TDS (Sybase) … no
Qt Testlib:
Qt SerialBus:
Socket CAN … yes
Socket CAN FD … yes
JasPer … no
MNG … no
TIFF … yes
WEBP … yes
Qt QML:
QML Locale … yes
Qt QML Models:
Qt Quick:
Direct3D 12 … no
Canvas item … yes
Flipable item … yes
GridView item … yes
ListView item … yes
Path support … yes
PathView item … yes
Repeater item … yes
Sprite item … yes
QtQuick3D:
Assimp … yes
System Assimp … no
Qt Scxml:
Qt 3D:
Assimp … yes
System Assimp … no
Aspects:
Render aspect … yes
Input aspect … yes
Logic aspect … yes
Extras aspect … yes
Qt 3D Renderers:
RHI Renderer … no
Autodesk FBX … no
Hover support … yes
QtXmlPatterns:
Qt Multimedia:
ALSA … no
GStreamer 1.0 … no
GStreamer 0.10 … no
OpenAL … no
PulseAudio … no
DirectShow … no
Qt TextToSpeech:
Flite … no
Qt Tools:
Qt Assistant … yes
Qt Designer … yes
kmap2qmap … yes
Qt Linguist … yes
makeqpf … yes
pixeltool … yes
qdbus … yes
qev … yes
qtdiag … yes
qtpaths … yes
qtplugininfo … yes
Qt Tools:
QDoc … no
ERROR: Feature ‘xkbcommon’ was enabled, but the pre-condition ‘libs.xkbcommon’ failed.
CMake Error at /path/superbuild/sb-qt5-configure.cmake:48 (message):
make[2]: *** [superbuild/CMakeFiles/qt5.dir/build.make:107: superbuild/qt5/stamp/qt5-configure] Error 1
make[1]: *** [CMakeFiles/Makefile2:6871: superbuild/CMakeFiles/qt5.dir/all] Error 2
You are building the ParaView-Superbuild using the paraview-for-ci docker image ?
That doesnt make much sense, the docker image already contains Qt and ParaView available to use.
could you tell me which docker image can I use to build paraview-superbuild?
But why do you want to build the ParaView-SuperBuild in a docker image ?
docker image has pre installed the required sofeware and librarys. for paraview 5.9.0,I use kitware/paraview:ci-superbuild-centos7-20201028 and it make compiling easy.
But the image I pointed to you already contains paraview. Why do you need to build it yourself ?
I found that paraview directory , thank you. but some cases , I modify the paraview source code , so I need to compile it .
In that case, you should not even use the superbuild, just build ParaView in any standard ubuntu docker image with Qt installed in it.
If you really need the superbuild, use an image for building it that is used for building 5.12: kitware/paraview:ci-superbuild-centos7-20230915. The 2020 image is probably missing things for a modern superbuild.
