I have created an H5 file that stores two variables. One I can view in paraview and the other I can’t because it fails to read attribute data. Error copied below.
I am able to supply a short file that shows the problem for me if that would help.
Thanks,
Francis
ERROR: In /home/buildslave/dashboards/buildbot/paraview-pvbinsdash-linux-shared-release_superbuild/build/superbuild/paraview/src/VTK/IO/Xdmf2/vtkXdmfHeavyData.cxx, line 1215
vtkXdmfReader (0x674f610): Failed to read attribute data
I was using ParaView 5.7 but have since upgraded to 5.8.
With the latest version I can say that the field, qr, looks correct. However, the pr field is weird after the initial plot and gives me a warning. Did you try both fields?
I get the same thing for the first snapshot. But when I advance to the subsequent ones is when things go batty. Could you please try advancing to see if you get the same problem as I do?
