Fail to run paraview on HPC
is there anyway I can run the paraview on HPC. I have access to HPC in university computer and paraview already in the HPC. I have load the module into the folder but I am still getting the error below.
Error:
paraFoam
Created temporary ‘25lsmeshcylinder.OpenFOAM’
QXcbConnection: Could not connect to display
AnyHelp would be apprecited!
make sure you set the display env var, eg:
export DISPLAY=:0
Still getting error ( is there a link or script available, which shows the steps how to use paraview on cluster). Most of the sites I research saying build paraview which is already being build then load which I did and run paraview it should run but in my case I am getting a error shown below.
 Created temporary '25lsmeshcylinder.OpenFOAM'
  QXcbConnection: Could not connect to display :0
wait, you are tyring to run paraFoam directly on the node ? There is probably no Xorg server running there. You are supposed to run pvserver and connect to it through a ssh tunnel.
See here for more info : https://www.paraview.org/Wiki/Setting_up_a_ParaView_Server
I supposed yes directly on it. Thanks for the advice. I read through the link and try it!
