I’m using the binary version for Windows from paraview.org 5.11.0
I loaded my python plugin into ParaView without any problems but when I try to load a data file using the plugin
I get a “Failed to create object” error. How can I resolve this error so that I am able to read the data file properly.
Here is the code I used for the plugin.
from vtkmodules.numpy_interface import dataset_adapter as dsa
from vtkmodules.vtkCommonDataModel import vtkDataSet
import numpy as np
@smproxy.reader(name="PythonHDFReader", label="Python-based HDF Reader",
extensions="hdf", file_description="HDF files")
@smproperty.input(name="Input", port_index=0)
@smdomain.datatype(dataTypes=["vtkPointSet"])
@smdomain.xml("""<InputArrayDomain attribute_type="point" name="input_normal" number_of_components="3" />""")
class HDF5Reader(VTKPythonAlgorithmBase):
def __init__(self):
super().__init__(nInputPorts=1, nOutputPorts=1, outputType="vtkPointSet")
self.WarpFactor = 1.0
self.NormalArray = ""
return 1
from vtkmodules.vtkCommonDataModel import imageToVTK
output = vtkPolyData.GetData(outInfo)
return 1
