Failed to find the required module VTK::ImagingMorphological
I am trying to use vtkImageOpenClose3D in a ParaView plugin, I have added VTK::ImagingMorphological in vtk.module under DEPENDS, but I get the cmake error
[cmake]   Failed to find the required module VTK::ImagingMorphological.
I can see the module in the paraView 5.11.2 source tree in VTK/Imaging/Morphological. I usually do this this way, what am I doing wrong in this case?
Thomas
Hi @Thomas_Theussl
This VTK module is not enabled in ParaView build because nothing in ParaView depends on it.
If you build ParaView yourself, you can enable it using the cmake var: VTK_MODULE_ENABLE_VTK_ImagingMorphological.
Best,
thank you! I will try that
it’s funny though, I checked my CMakeCache.txt and it said VTK_MODULE_ENABLE_VTK_ImagingMorphological:STRING=DEFAULT as do all the other modules I use, how do I find out what DEFAULT means?
It depends on what ParaView needs, which is automatic, there is no such feedback from CMake directly.
DEFAULT is, for VTK modules in a ParaView build, DONT_WANT. For ParaView client and “core” (non-incubator) modules, PARAVIEW_BUILD_ALL_MODULES=ON will treat DEFAULT as WANT. Note that any non-DEFAULT group settings that modules belong to apply before (ultimately) falling back on PARAVIEW_BUILD_ALL_MODULES.
