failure to read xdmf files generated by Fenics
I am using Paraview-5.8.1-RC2 with a MacOS Mojave 10.14.5 with 16Gb Ram
I get errors message (see below) when I open the attached xdmf file (generated by Fenics). velocity.xdmf (24.1 KB)
The velocity.h5 companion file is present in the same directory. It is 9Mo so I don’t include it here. I can provide a link if necessary.
I tried to open the file with Paraview-5.8.0 and Paraview-5.6.2 and got the same issue.
I could not find an answer in the posts about xdmf.
Any help appreciated.
ERROR: In /Users/kitware/dashboards/buildbot-slave/88b2a88f/build/superbuild/paraview/src/VTK/IO/Xdmf2/vtkXdmfReader.cxx, line 476
vtkXdmfReader (0x7fbb45582580): Failed to read data.
ERROR: In /Users/kitware/dashboards/buildbot-slave/88b2a88f/build/superbuild/paraview/src/VTK/Common/ExecutionModel/vtkExecutive.cxx, line 753
vtkPVCompositeDataPipeline (0x600002298a80): Algorithm vtkFileSeriesReader(0x60000266cf00) returned failure for request: vtkInformation (0x60000059b780)
Debug: Off
Modified Time: 330481
Reference Count: 1
Registered Events: (none)
Request: REQUEST_DATA
FROM_OUTPUT_PORT: 0
ALGORITHM_AFTER_FORWARD: 1
FORWARD_DIRECTION: 0
Use the XDMF3 reader option.
I can choose between XDMF Reader or xdmf3ReaderS or xdfmf3ReaderT.
But the last two make Paraview crash. So I can only open with XDMF Reader and I still have the same problem.
Seems I didn’t generate the xdmf file correctly.
I did it in python with the following commands:
First I create the file before my time loop
xdmffile_u = XDMFFile(‘velocity.xdmf’)
then I save the time values within the time loop to file (XDMF/HDF5)
xdmffile_u.write(u, t)
Thanks to https://fenicsproject.discourse.group/t/loading-xdmf-file-in-paraview/2291
I solved the issue inserting the command
xdmffile_u.parameters[“flush_output”] = True
just after the file creation:
Now all three xdmf readers work correctly. No need to use xdfm3 btw.
Could you go through step by step on how to use this command. I’m currently extracting an xdmf file from a fenicsproject machine and I desperately need help on this topic. If you could please go through step by step on how to make this work that would be great.
