Fastest way to create 3D topography surface (with holes)
In Python plugin I use the code below to create 3D polydata from reqular 2D grid with holes (NoData values) but it’s works too slow. Maybe should I use some other data type or processing instead?
# Define points and triangles for mesh
vtk_points = vtkPoints()
vtk_cells = vtkCellArray()
# Build the meshgrid manually
count = 0
# iterate array
for j in range(0,len(ys)-2):
	for i in range(0,len(xs)-2):
		# check area
		if not mask[j,i] or not mask[j+1,i] or not mask[j,i+1] or not mask[j+1,i+1]:
			continue
		# Triangle 1
		vtk_points.InsertNextPoint(xs[i],   ys[j],   values[j,i])
		vtk_points.InsertNextPoint(xs[i],   ys[j+1], values[j+1,i])
		vtk_points.InsertNextPoint(xs[i+1], ys[j],   values[j,i+1])
		triangle = vtkTriangle()
		triangle.GetPointIds().SetId(0, count)
		triangle.GetPointIds().SetId(1, count + 1)
		triangle.GetPointIds().SetId(2, count + 2)
		vtk_cells.InsertNextCell(triangle)
		# Triangle 2
		vtk_points.InsertNextPoint(xs[i+1], ys[j+1], values[j+1,i+1])
		triangle.GetPointIds().SetId(0, count + 3)
		triangle.GetPointIds().SetId(1, count + 4)
		triangle.GetPointIds().SetId(2, count + 5)
		count += 6
# Create a polydata object
trianglePolyData = vtkPolyData()
# Add the geometry and topology to the polydata
trianglePolyData.SetPoints(vtk_points)
#trianglePolyData.GetPointData().SetScalars(colors)
trianglePolyData.SetPolys(vtk_cells)
Can you share an input data and the desired output ?
Source datasets:
Download the global GEBCO_2019 Grid - in netCDF format (11 Gbytes, 12 Gbytes uncompressed)
Admin 0 – Countries - Download without boundary lakes
Actual plugin code to generate vtkUnstructuredGrid with Z coordinate for coloring:
And to add attribute to it (like to country name for coloring and labeling):
This is the output:
For now, I don’t know more optimal way to get produce this visualization. Is it the optimal datatype for the task? We have Z coordinate in the mesh geometries and as the separate attribute - could we exclude it but still have the ability for mesh coloring by Z coordinate? Could we save additional attribute like to country name by more optimal way (for now it’s saved separately for every cell as I see)?
I am trying to learn what is efficient and I came across this https://vtk.org/Wiki/VTK/Tutorials/DataArrays
It mainly deals with the loss of performances related to the generic API.
From what I have read but not tested in the source code, using iterator + a second class to parallelize with multithreading seems the way to go (I am currently looking at ParaView-v5.7.0/VTK/Imaging/Core/vtkImageBlend.cxx).
The next thing would be to reduce cache misses on the 2D array values by adding a Morton Index (https://en.wikipedia.org/wiki/Z-order_curve)
Hopefully this would help.
Best regards
