build environment: vs2015 x64, paraview 5.7.0, windows 10
I got compile error: fatal error C1002: compiler is out of heap space in pass 2 for project AcceleratorsVTKm.
How much system memory do you have?
VTK-m is a very heavy memory demanding project to build and is a dependency of ParaView, you have the following possibilities
- Buy more ram (you will need 2Gb by parallel thread to be able to build VTK-m)
- Use ninja-build instead of VisualStudio (actually quite easy)
- Disable VTK-m by setting the PARAVIEW_USE_VTKM cmake option to false (you will miss some features in ParaView)
16gb. I disable PARAVIEW_USE_VTKM, and I compile sucessfully.
Could you tell me some details or give me a link for the missing features about VTK-m?
- Accelerators Plugin that provide a few filters from VTKm
- Fast LOD that will fallback to standard LOD
Thank you. However, when I use vs2019 to compile paraview 5.7.0, I didn’t get this error message.
Good news, looks like VS2019 is monitoring memory when building !
The VTK-m is currently looking at how we can restructure some code to consume less memory when compiling. This won’t happen overnight but it will happen
