Floating point exception when trying to run ./paraview in linux
When I try to start paraview version 5.10.1-MPI in chrome os linux, it immediately fails with this error.
./paraview
error: exception occurred: Floating-point exception
I installed dependencies with this command:
sudo apt-get install git cmake build-essential libgl1-mesa-dev libxt-dev qt5-default libqt5x11extras5-dev libqt5help5 qttools5-dev qtxmlpatterns5-dev-tools libqt5svg5-dev python3-dev python3-numpy libopenmpi-dev libtbb-dev ninja-build
I had to remove qt5-default in the above command for it to work. Supposedly a workaround is to use:
sudo apt-get install qtbase5-dev qtchooser qt5-qmake qtbase5-dev-tools
I think the problem is with mpiexec. When I compile paraview from source, it shows much more debug info.
penguin:32715] *** Process received signal ***
[penguin:32715] Signal: Floating point exception (8)
[penguin:32715] Signal code: Integer divide-by-zero (1)
[penguin:32715] Failing at address: 0x7f03d5dbd06b
[penguin:32715] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x14140)[0x7f03d607e140]
[penguin:32715] [ 1] /lib/x86_64-linux-gnu/libhwloc.so.15(+0x4206b)[0x7f03d5dbd06b]
[penguin:32715] [ 2] /lib/x86_64-linux-gnu/libhwloc.so.15(+0x42f67)[0x7f03d5dbdf67]
[penguin:32715] [ 3] /lib/x86_64-linux-gnu/libhwloc.so.15(+0x4378b)[0x7f03d5dbe78b]
[penguin:32715] [ 4] /lib/x86_64-linux-gnu/libhwloc.so.15(+0x830e)[0x7f03d5d8330e]
[penguin:32715] [ 5] /lib/x86_64-linux-gnu/libhwloc.so.15(hwloc_topology_load+0x4a7)[0x7f03d5d8b557]
[penguin:32715] [ 6] /lib/x86_64-linux-gnu/libopen-pal.so.40(opal_hwloc_base_get_topology+0x1194)[0x7f03d5e6c4f4]
[penguin:32715] [ 7] /usr/lib/x86_64-linux-gnu/openmpi/lib/openmpi3/mca_ess_hnp.so(+0x5146)[0x7f03d5b70146]
[penguin:32715] [ 8] /lib/x86_64-linux-gnu/libopen-rte.so.40(orte_init+0x29c)[0x7f03d611864c]
[penguin:32715] [ 9] /lib/x86_64-linux-gnu/libopen-rte.so.40(orte_daemon+0x22d)[0x7f03d60c502d]
[penguin:32715] [10] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xea)[0x7f03d5ecbd0a]
[penguin:32715] [11] orted(+0x115a)[0x56f41c94a15a]
[penguin:32715] *** End of error message ***
[penguin:32712] [[INVALID],INVALID] ORTE_ERROR_LOG: Unable to start a daemon on the local node in file ../../../../../../orte/mca/ess/singleton/ess_singleton_module.c at line 716
[penguin:32712] [[INVALID],INVALID] ORTE_ERROR_LOG: Unable to start a daemon on the local node in file ../../../../../../orte/mca/ess/singleton/ess_singleton_module.c at line 172
(continues)
When I run mpiexec:
[penguin:32745] *** Process received signal ***
[penguin:32745] Signal: Floating point exception (8)
[penguin:32745] Signal code: Integer divide-by-zero (1)
[penguin:32745] Failing at address: 0x7e36eca5a06b
[penguin:32745] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x3bd60)[0x7e36ecac9d60]
[penguin:32745] [ 1] /lib/x86_64-linux-gnu/libhwloc.so.15(+0x4206b)[0x7e36eca5a06b]
[penguin:32745] [ 2] /lib/x86_64-linux-gnu/libhwloc.so.15(+0x42f67)[0x7e36eca5af67]
[penguin:32745] [ 3] /lib/x86_64-linux-gnu/libhwloc.so.15(+0x4378b)[0x7e36eca5b78b]
[penguin:32745] [ 4] /lib/x86_64-linux-gnu/libhwloc.so.15(+0x830e)[0x7e36eca2030e]
[penguin:32745] [ 5] /lib/x86_64-linux-gnu/libhwloc.so.15(hwloc_topology_load+0x4a7)[0x7e36eca28557]
[penguin:32745] [ 6] /lib/x86_64-linux-gnu/libopen-pal.so.40(opal_hwloc_base_get_topology+0x1194)[0x7e36ecd084f4]
[penguin:32745] [ 7] /usr/lib/x86_64-linux-gnu/openmpi/lib/openmpi3/mca_ess_hnp.so(+0x5146)[0x7e36ec84f146]
[penguin:32745] [ 8] /lib/x86_64-linux-gnu/libopen-rte.so.40(orte_init+0x29c)[0x7e36ecdcd64c]
[penguin:32745] [ 9] /lib/x86_64-linux-gnu/libopen-rte.so.40(orte_submit_init+0x91d)[0x7e36ecdd1dcd]
[penguin:32745] [10] mpiexec(+0x12bf)[0x564d685ba2bf]
[penguin:32745] [11] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xea)[0x7e36ecab4d0a]
[penguin:32745] [12] mpiexec(+0x113a)[0x564d685ba13a]
[penguin:32745] *** End of error message ***
Floating point exception (core dumped)
Hi @foghorn ,
How do you install ParaView ?
Are you using a ARM or x86 device ?
Best,
I unzipped the tarball for 5.10.1-MPI, ran the apt-get install commands in the 1st post (with “qt5-default” removed from the first command), and then ran ./paraview .
I also built it from source using the instructions at:
https://gitlab.kitware.com/paraview/paraview/blob/master/Documentation/dev/build.md
This showed debug messages but also failed.
Finally, I built 5.10.1-MPI from source with the MPI option turned OFF. This runs successfully.
So, it is definitely a problem with MPI on my system. I want to continue to try to get the MPI version of paraview working.
My device architecture is x86_64.
foghorn,
I would suggest that you NOT use the MPI version. MPI builds have been shown to be problematic for me with builtiin server (i.e., not connected to a remote server). I always give my users the non MPI version. ParaView is becoming threaded, which negates the need for MPI.
Hmmm … I just looked, and they are all MPI enabled. I will poke the developers and see what they say.
