I have created a custom filter from the Annotate Time source and exported as XML. I then edited the XML to create a plugin that I can autoload from my plugins directory.
When I use it, instead of text rendered in the Renderview, it creates by a table displayed in the spreadsheet view. It will render happily in the Renderview when visibility is set. Is there a way I can force the view type within the xml so the filter works in the same way as Annotate Time?
I’ve just tried similar with the Python Annotation filter.
If I use the filter to display time, the text renders in the Renderview. If I create a custom filter and use it within the same session (Ie no XML exported and re-imported), then the spreadsheet view pops up.
I tried setting both Representation and RepresentationType in the hints and found no change. In the end I have copied the Annotate Time XML from Sources.XML and edited as below to achieve what I wanted. Again, a representation type is not required in the hints.
<ServerManagerConfiguration>
<ProxyGroup name="sources">
<SourceProxy class="vtkTimeToTextConvertor"
label="Annotate Angle"
name="TimeToAngleConvertorSource">
<Documentation long_help="Shows the animation time as an angle in the view."
short_help="Show animation time as angle">The Annotate Angle
source can be used to show the animation angle in text
annotation.</Documentation>
<StringVectorProperty command="SetFormat"
default_values="Angle: %06.2f°"
name="Format"
number_of_elements="1"
panel_visibility="default">
<Documentation>This property specifies the format used to display the
input angle (using printf style).</Documentation>
</StringVectorProperty>
<Hints>
<ShowInMenu category="My Source Category" icon="..\..\ParaviewPlugins\icons\icons8-counter-50.png" />
<OutputPort index="0"
name="Output-0"
type="text" />
</Hints>
</SourceProxy>
</ProxyGroup>
It seems that creating a compound/ custom filter from this source within the GUI changes the output type.
