Dear Developers,
We use fortran simulation codes, and we would like to try Catalyst on them.
I create an Apptainer container Ubuntu 24.04LTS with dependencies for compilations
Then install ParaView-5.13.3-MPI-Linux-Python3.10-x86_64.tar.gz inside
Then install Mpich, i red somewhere that the Mpich version have to match the one used in Paraview, so i checked :
/usr/local/ParaView-5.13.3-MPI-Linux-Python3.10-x86_64/bin/mpiexec --version which gives;
Version: 4.1.2
‘FC=/opt/rh/devtoolset-10/root/usr/bin/gfortran’
So i my container i compiled and installed 4.1.2 version of Mpich
- Then install and compile catalyst-master.tar.gz’ with:
cmake -G Ninja -DCMAKE_INSTALL_PREFIX=/usr/local/Catalyst -DCMAKE_BUILD_TYPE=Release -DCATALYST_USE_MPI:BOOL=ON -DCATALYST_WRAP_FORTRAN:BOOL=ON -DCATALYST_WRA
P_PYTHON:BOOL=ON -DCMAKE_C_COMPILER=/usr/local/Mpich/bin/mpicc -DCMAKE_CXX_COMPILER=/usr/local/Mpich/bin/mpicxx -DCMAKE_Fortran_COMPILER=/usr/local/Mpich/bin/mpi
f90 /usr/local/catalyst-master
- I noticed that if i execute ctest, test 17 fail, i haven’t understood why…so skipped it for now
- Then install and try build ‘paraview-master-Examples.tar.gz’
for now i just try Catalyst2 examples: Everything compile but when i try to execute fortran one, i.e.:
cd /opt/paraview-master-Examples/Examples/Catalyst2/Fortran90FullExample/
./build/bin/Fortran90FullExampleV2 catalyst_pipeline.py
i got these errors:
./build/bin/Fortran90FullExampleV2: /usr/local/ParaView-5.13.3-MPI-Linux-Python3.10-x86_64/lib/libgfortran.so.5: versionGFORTRAN_10' not found (required by ./build/bin/Fortran90FullExampleV2) ./build/bin/Fortran90FullExampleV2: /usr/local/ParaView-5.13.3-MPI-Linux-Python3.10-x86_64/lib/libgfortran.so.5: versionGFORTRAN_9’ not found (required by /usr/local/Mpich/lib/libmpifort.so.12)After some investigations, i noticed that PV-5.13.3, use, not only MPICH-4.1.2, but that this one was built with ‘FC=/opt/rh/devtoolset-10/root/usr/bin/gfortran’ which is older than mine: GNU Fortran (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0
So my question is : how to solve that ? I have seen that the OS repository propose a gfortran-10/noble 10.5.0-4ubuntu2 amd64. It should be more close of the version used by PV based on devtoolset-10, which is a little bit old. Do you think it could solve the problem ?
Of course I can give you all my scripts for the whole build process;
Thank i advance for your advices and help
Best regards
JM
