Frame rate number needs improvement
I’m rendering volumes in a paraview client (macos). The data lives on a different machine running pvserver. I notice that Paraview uses remote rendering all the time for even small volumes and there’s no way to override this. This is not interactive at all, even on a really good connection. I wanted to check the fps but the values it shows do not make sense.
If you turn on the “Show Annotation” checkbox in ParaView Settings → Render View, the value shown for the “Frame rate (approx): … fps” is unrealistic. It shows numbers in the range 2400-2600, but that’s not true.
In the screen-recording below, only the orientation axes is drawn. vtkRenderWindow::Render() takes 0.4ms so 1000/0.4 ~ 2500 is where it got that number from.
I believe the label is incorrect, and should be called render throughput. A frame rate should take into account display refresh, qt blits.
Remote Render Threshold
As I’ve said in my post, there’s no way to override it, atleast in 6.2.0. What I’m noticing is that setting has no effect when a volume representation is shown in the render view.
I’ve set it to 1024000 (~1TB) and even for a small 35 KB volume, it still does remote rendering!
Ha! thats a bug then.
I can confirm that I’ve felt this same behavior but had just chalked it up to “must just be some inherent limitation in remote-local mode” and so had accepted it as the status quo. So thanks @jaswantp for reporting this!
