Hi all!
I’m trying to rescale a colourbar to force the minimum at zero.
It seems I can only do this by setting both the minimum and maximum.
However I do not know the maximum a priori and therefore cannot hardcode it.
I am doing the following:
# create a new 'Xdmf3ReaderS'
mobile_concentrationxdmf = Xdmf3ReaderS(
registrationName="mobile_concentration.xdmf",
FileName=["./mobile_concentration.xdmf"],
# setup the visualization in view 'renderView1'
# show data from mobile_concentrationxdmf
mobile_concentrationxdmfDisplay = Show(
mobile_concentrationxdmf, renderView1, "UnstructuredGridRepresentation"
animationScene1 = GetAnimationScene()
animationScene1.GoToLast()
# set scalar coloring
ColorBy(mobile_concentrationxdmfDisplay, ("POINTS", "mobile_concentration"))
# get min and max of Color
info = mobile_concentrationxdmf.GetDataInformation().DataInformation
arrayInfo = info.GetArrayInformation(
"mobile_concentration", vtk.vtkDataObject.FIELD_ASSOCIATION_POINTS
min_conc, max_conc= arrayInfo.GetComponentRange(0)
# get color transfer function/color map for 'Color'
colorLUT = GetColorTransferFunction("mobile_concentration")
# Apply a preset using its name. Note this may not work as expected when presets have duplicate names.
colorLUT.ApplyPreset("Viridis (matplotlib)", True)
colorLUT.RescaleTransferFunction(0, max_conc)
op = GetOpacityTransferFunction("mobile_concentration")
op.RescaleTransferFunction(0, max_conc)
It works just fine for datasets that have only one time step, but here, even though I go to the last time step on the animation, GetComponentRange only returns the first timestep.
Where should I select the last timestep?
Thanks in advance for the help!
Cheers
Remi
